Forum Index : Microcontroller and PC projects : Micromite eXtreme: The PCB portfolio
Page 3 of 3 | |||||
enzo1965 Newbie Joined: 30/08/2018 Location: ItalyPosts: 2 |
Many thanks for fast reply |
geeken Newbie Joined: 13/01/2018 Location: United StatesPosts: 20 |
Hi Peter Appreciate you producing MMX-144 v1.2 PCB's & having them made available. What would be the changes over v1.1 - is there a change-spec doc or a back-of-serviette-list available anywhere ? Or is it as "easy" as comparing the schematics and/or the gerbers ? Ken |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8601 |
V1.1 has a through hole oscillator that is really only specced for 5V running at 3.3V. V1.2 has either a 3.3V SMD oscillator or a 5V through hole version operating properly at 5V with a voltage divider on the output driving the MZ |
karjo238 Regular Member Joined: 12/10/2018 Location: New ZealandPosts: 54 |
I would just like to ask one silly question - what type of plug is the Nunchuck controller? I am looking at purchasing one of these and converting my version of Missile Command to it (amongst other things), and want to hook up a joystick, but I'm not 100% certain as to what options I have. Many thanks, Joseph. |
Don't know the spec of the physical plug but the I/F is I2C. I would really recommend the Armmite H7 rather than the MMX. It has a 256 colour driver for the 800x480 display which allows a complete frame buffer to be kept in memory whilst leaving masses of memory still available for Sprite buffers etc. It is also much cheaper (Nucleo-H743 + backpack PCB) and twice as fast. The only plus for the MMX is VGA. There are code compatible. |
paceman Guru Joined: 07/10/2011 Location: AustraliaPosts: 1328 |
As Peter says, interface is I2C and there is quite a bit of info on the forum, most going back to early 2012 and using the Maximite. Here's one link Nunchuck Just do a normal forum search for "nunchuck" or as was occasionally mis-quoted "numchuck". Greg |
Page 3 of 3 |
