Local Time 18:21 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - RKF78 numerical method
cdeagle
Posted: 08:40am 27 Mar 2017
This post describes an MMBASIC computer program that can be used to solve a system of first-order differential equations using the variable step size Runge-Kutta-Fehlberg 7(8) numerical method. If you understand the first sentence, read on.
To illustrate the use of Fehlberg's customization of the classic Runge-Kutta method, I've written a demo program that uses this technique to solve the initial-value-problem (IVP) of Keplerian orbital motion. Given initial orbital conditions and a propagation duration, the software integrates the first-order system of differential that define the Keplerian or unperturbed motion of a body orbiting the Earth.
For a body in a closed orbit, its Keplerian orbital period is equal to 2 * pi * sqr(a^3/mu), where a is the semimajor axis of the orbit and mu is the gravitational constant of the Earth. The orbital period is the time needed to travel from some location on the orbit, once around, to the same location on that orbit.
We can use this fact to test and "calibrate" a diffeq numerical method. If the technique is working, the components of the position and velocity vectors (also called the state vector) should match "closely" at the beginning and exactly one or more orbital periods later. The calibration involves changing the truncation error value (TE), propagating the object for say ten orbits and looking at the closure of the state vector. We can "tune" the TE value to predict state vector differences we are willing to accept.
Here's the program output for this example. It illustrates the initial and and final orbital elements and corresponding position and velocity vectors. The program also displays the difference in the initial and predicted components of the position and velocity vectors, in the units of meters and meters/second. The truncation error for this case is 1.0e-10.
initial orbital elements and state vector
semimajor axis 26553.1755 kilometers
eccentricity 0.7350000007
orbital inclination 63.4350 degrees
argument of perigee 270.0000 degrees
RAAN 100.0000 degrees
true anomaly 45.0000 degrees
orbital period 717.6859 minutes
position vector x-component 1515.374483 kilometers
position vector y-component 6035.274923 kilometers
position vector z-component -5080.745408 kilometers
position vector magnitude 8033.360263 kilometers
velocity vector x-component -3.2103497224 kilometers/second
velocity vector y-component 7.8012017187 kilometers/second
velocity vector z-component 3.6138337387 kilometers/second
velocity vector magnitude 9.1774118291 kilometers/second
final orbital elements and state vector
eccentricity 0.7349999997
position vector x-component 1515.374620 kilometers
position vector y-component 6035.274594 kilometers
position vector z-component -5080.745565 kilometers
position vector magnitude 8033.360142 kilometers
velocity vector x-component -3.2103496709 kilometers/second
velocity vector y-component 7.8012019147 kilometers/second
velocity vector z-component 3.6138335697 kilometers/second
velocity vector magnitude 9.1774119109 kilometers/second
state vector differences (final - initial)
position vector x-component 0.137424 meters
position vector y-component -0.328237 meters
position vector z-component -0.156677 meters
velocity vector x-component 0.0000514728 meters/second
velocity vector y-component 0.0001958789 meters/second
velocity vector z-component -0.0001694100 meters/second
Here are the state vector differences for a truncation error value of 1.0e-12. Better prediction and longer run times.
position vector x-component 0.004723 meters
position vector y-component -0.011434 meters
position vector z-component -0.005331 meters
velocity vector x-component 0.0000017305 meters/second
velocity vector y-component 0.0000068171 meters/second
velocity vector z-component -0.0000057761 meters/second
Here's the source code for the demo driver, RKF integrator and support functions and subroutines.
' demo_rkf78.bas March 27, 2017
' this program demonstrates how to interact
' with the rkf78.bas subroutine which
' solves a system of first-order nonlinear
' differential equations
' the system of differential equations is defined
' in a subroutine with the following syntax
' sub diffeq(t, y(), ydot())
' where t is the current time, y() is the current
' integration vector and ydot() is the system of
' first order differential equations evaluated at
' t and y()
' this example solves the differential equations
' of "Keplerian" (unperturbed) orbital motion
' MicroMite eXtreme version
option default float
option base 1
dim ch(13), alph(13), beta(13, 12)
dim ri(3), vi(3), rf(3), vf(3)
dim yold(6), ynew(6), oevi(6), oevf(6)
dim neq as integer, ti, tf, h, tetol
const dtr = pi / 180.0, rtd = 180.0 / pi, pi2 = 2.0 * pi, pidiv2 = 0.5 * pi
' gravitational constant (kilometer^3/second^2)
const mu = 398600.4415
' define rkf78 integration coefficients
ch(6) = 34 / 105
ch(7) = 9 / 35
ch(8) = ch(7)
ch(9) = 9 / 280
ch(10) = ch(9)
ch(12) = 41 / 840
ch(13) = ch(12)
alph(2) = 2 / 27
alph(3) = 1 / 9
alph(4) = 1 / 6
alph(5) = 5 / 12
alph(6) = 0.5
alph(7) = 5 / 6
alph(8) = 1 / 6
alph(9) = 2 / 3
alph(10) = 1 / 3
alph(11) = 1
alph(13) = 1
beta(2, 1) = 2 / 27
beta(3, 1) = 1 / 36
beta(4, 1) = 1 / 24
beta(5, 1) = 5 / 12
beta(6, 1) = 0.05
beta(7, 1) = -25 / 108
beta(8, 1) = 31 / 300
beta(9, 1) = 2
beta(10, 1) = -91 / 108
beta(11, 1) = 2383 / 4100
beta(12, 1) = 3 / 205
beta(13, 1) = -1777 / 4100
beta(3, 2) = 1 / 12
beta(4, 3) = 1 / 8
beta(5, 3) = -25 / 16
beta(5, 4) = -beta(5, 3)
beta(6, 4) = 0.25
beta(7, 4) = 125 / 108
beta(9, 4) = -53 / 6
beta(10, 4) = 23 / 108
beta(11, 4) = -341 / 164
beta(13, 4) = beta(11, 4)
beta(6, 5) = 0.2
beta(7, 5) = -65 / 27
beta(8, 5) = 61 / 225
beta(9, 5) = 704 / 45
beta(10, 5) = -976 / 135
beta(11, 5) = 4496 / 1025
beta(13, 5) = beta(11, 5)
beta(7, 6) = 125 / 54
beta(8, 6) = -2 / 9
beta(9, 6) = -107 / 9
beta(10, 6) = 311 / 54
beta(11, 6) = -301 / 82
beta(12, 6) = -6 / 41
beta(13, 6) = -289 / 82
beta(8, 7) = 13 / 900
beta(9, 7) = 67 / 90
beta(10, 7) = -19 / 60
beta(11, 7) = 2133 / 4100
beta(12, 7) = -3 / 205
beta(13, 7) = 2193 / 4100
beta(9, 8) = 3
beta(10, 8) = 17 / 6
beta(11, 8) = 45 / 82
beta(12, 8) = -3 / 41
beta(13, 8) = 51 / 82
beta(10, 9) = -1 / 12
beta(11, 9) = 45 / 164
beta(12, 9) = 3 / 41
beta(13, 9) = 33 / 164
beta(11, 10) = 18 / 41
beta(12, 10) = 6 / 41
beta(13, 10) = 12 / 41
beta(13, 12) = 1
' define initial classical orbital elements
oevi(1) = 26553.175464
oevi(2) = 0.735
oevi(3) = 63.435 * dtr
oevi(4) = 270.0 * dtr
oevi(5) = 100.0 * dtr
oevi(6) = 45.0 * dtr
' compute initial state vector
orb2eci(mu, oevi(), ri(), vi())
print " "
print "initial orbital elements and state vector"
print "-----------------------------------------"
print " "
oeprint(mu, oevi())
print " "
svprint(ri(), vi())
' define number of differential equations
neq = 6
' initial step size guess (seconds)
h = 1.0
' truncation error tolerance
tetol = 1.0e-10
' load initial integration vector
for i% = 1 to 3
yold(i%) = ri(i%)
yold(i% + 3) = vi(i%)
next i%
' initial time (seconds)
ti = 0.0
' final time = ten keplerian orbital periods (seconds)
tau = pi2 * sqr(oevi(1) * oevi(1) * oevi(1) / mu)
tf = 10.0 * tau
' integrate equations of motion
rkf78(neq, ti, tf, h, tetol, yold(), ynew())
' unload final state vector
for i% = 1 to 3
rf(i%) = ynew(i%)
vf(i%) = ynew(i% + 3)
next i%
' compute and print final orbital elements
eci2orb(mu, rf(), vf(), oevf())
print " "
print " "
print "final orbital elements and state vector"
print "---------------------------------------"
print " "
oeprint(mu, oevf())
print " "
svprint(rf(), vf())
print " "
print " "
print "state vector differences (final - initial)"
print "------------------------------------------"
print " "
print "position vector x-component ", str$(1000.0 * (rf(1) - ri(1)), 0, 6), " meters"
print "position vector y-component ", str$(1000.0 * (rf(2) - ri(2)), 0, 6), " meters"
print "position vector z-component ", str$(1000.0 * (rf(3) - ri(3)), 0, 6), " meters"
print " "
print "velocity vector x-component ", str$(1000.0 * (vf(1) - vi(1)), 0, 10), " meters/second"
print "velocity vector y-component ", str$(1000.0 * (vf(2) - vi(2)), 0, 10), " meters/second"
print "velocity vector z-component ", str$(1000.0 * (vf(3) - vi(3)), 0, 10), " meters/second"
print " "
end
sub rkf78 (neq, ti, tf, h, tetol, xi(), xf())
' solve first order system of differential equations
' Runge-Kutta-Fehlberg 7(8) method
' input
' neq = number of differential equations
' ti = initial simulation time (seconds)
' tf = final simulation time (seconds)
' h = initial guess for integration step size
' tetol = truncation error tolerance (non-dimensional)
' xi() = integration vector at time = ti
' output
' xf() = integration vector at time = tf
local xdot(neq), xwrk(neq), f(neq, 13)
local sdt, dt, temp, twrk
' compute integration "direction"
sdt = sgn(tf - ti)
dt = abs(h) * sdt
do
' load "working" time and integration vector
twrk = ti
for i% = 1 to neq
xwrk(i%) = xi(i%)
next i%
' check for last delta-t
if (abs(dt) > abs(tf - ti)) then dt = tf - ti
' check for end of integration period
if (abs(ti - tf) < 1.0e-12) then
for i% = 1 to neq
xf(i%) = xi(i%)
next i%
' finished - exit do loop
exit do
end if
' evaluate equations of motion
diffeq(ti, xi(), xdot())
for i% = 1 to neq
f(i%, 1) = xdot(i%)
next i%
' compute solution
for k% = 2 to 13
kk% = k% - 1
for i% = 1 to neq
temp = 0.0
for j% = 1 to kk%
temp = temp + beta(k%, j%) * f(i%, j%)
next j%
xi(i%) = xwrk(i%) + dt * temp
next i%
ti = twrk + alph(k%) * dt
for j% = 1 to neq
f(j%, k%) = xdot(j%)
next j%
next k%
for i% = 1 to neq
temp = 0.0
for l% = 1 to 13
temp = temp + ch(l%) * f(i%, l%)
next l%
next i%
' truncation error calculations
xerr = tetol
for i% = 1 to neq
ter = abs((f(i%, 1) + f(i%, 11) - f(i%, 12) - f(i%, 13)) * ch(12) * dt)
tol = abs(xi(i%)) * tetol + tetol
tconst = ter / tol
if (tconst > xerr) then xerr = tconst
next i%
' compute new step size
dt = 0.8 * dt * (1.0 / xerr) ^ (1.0 / 8.0)
if (xerr > 1.0) then
' reject current step and try again
ti = twrk
for i% = 1 to neq
xi(i%) = xwrk(i%)
next i%
else
' accept current step '
' perform graphics, additional '
' calculations, etc. at this point '
end if
loop
end sub
sub diffeq (t, y(), ydot())
' first order equations of orbital motion
' Keplerian motion - no perturbations
' input
' t = simulation time (seconds)
' y() = state vector
' output
' ydot() = integration vector
local rmag, rcubed
rmag = sqr(y(1) * y(1) + y(2) * y(2) + y(3) * y(3))
rcubed = rmag * rmag * rmag
ydot(1) = y(4)
ydot(2) = y(5)
ydot(3) = y(6)
ydot(4) = -mu * y(1) / rcubed
ydot(5) = -mu * y(2) / rcubed
ydot(6) = -mu * y(3) / rcubed
end sub
sub eci2orb (mu, r(), v(), oev())
' convert eci state vector to six classical orbital
' elements via equinoctial elements
' input
' mu = central body gravitational constant (km**3/sec**2)
' r() = eci position vector (kilometers)
' v() = eci velocity vector (kilometers/second)
' output
' oev(1) = semimajor axis (kilometers)
' oev(2) = orbital eccentricity (non-dimensional)
' (0 <= eccentricity < 1)
' oev(3) = orbital inclination (radians)
' (0 <= inclination <= pi)
' oev(4) = argument of perigee (radians)
' (0 <= argument of perigee <= 2 pi)
' oev(5) = right ascension of ascending node (radians)
' (0 <= raan <= 2 pi)
' oev(6) = true anomaly (radians)
' (0 <= true anomaly <= 2 pi)
local rmag, vmag, sma, p, q, const1
local h, xk, x1, y1, eccm, inc, xlambdat
local raan, argper, tanom
local rhat(3), hhat(3), vtmp(3), ecc(3)
local hv(3), fhat(3), ghat(3)
' position and velocity magnitude
rmag = vecmag(r())
vmag = vecmag(v())
' position unit vector
uvector(r(), rhat())
' angular momentum vectors
vcross(r(), v(), hv())
uvector(hv(), hhat())
' eccentricity vector
for i% = 1 to 3
vtmp(i%) = v(i%) / mu
next i%
vcross(vtmp(), hv(), ecc())
for i% = 1 to 3
ecc(i%) = ecc(i%) - rhat(i%)
next i%
' semimajor axis
sma = 1.0 / (2.0 / rmag - vmag * vmag / mu)
p = hhat(1) / (1.0 + hhat(3))
q = -hhat(2) / (1.0 + hhat(3))
const1 = 1.0 / (1.0 + p * p + q * q)
fhat(1) = const1 * (1.0 - p * p + q * q)
fhat(2) = const1 * 2.0 * p * q
fhat(3) = -const1 * 2.0 * p
ghat(1) = const1 * 2.0 * p * q
ghat(2) = const1 * (1.0 + p * p - q * q)
ghat(3) = const1 * 2.0 * q
h = vdot(ecc(), ghat())
xk = vdot(ecc(), fhat())
x1 = vdot(r(), fhat())
y1 = vdot(r(), ghat())
' orbital eccentricity
eccm = sqr(h * h + xk * xk)
' orbital inclination
inc = 2.0 * atn(sqr(p * p + q * q))
' true longitude
xlambdat = atan3(y1, x1)
' check for equatorial orbit
if (inc > 1.0e-8) then
raan = atan3(p, q)
else
raan = 0.0
end if
' check for circular orbit
if (eccm > 1.0e-8) then
argper = modulo(atan3(h, xk) - raan)
else
argper = 0.0
end if
' true anomaly (radians)
tanom = modulo(xlambdat - raan - argper)
' load orbital element vector
oev(1) = sma
oev(2) = eccm
oev(3) = inc
oev(4) = argper
oev(5) = raan
oev(6) = tanom
end sub
sub orb2eci(mu, oev(), r(), v())
' convert classical orbital elements to state vector
' input
' mu = gravitational constant (km**3/sec**2)
' output
' r() = position vector (kilometers)
' v() = velocity vector (kilometers/second)
local sma, ecc, inc, argper, raan, tanom
local slr, rm, arglat, sarglat, carglat
local c4, c5, c6, sinc, cinc, sraan, craan
' unload orbital elements array
sma = oev(1)
ecc = oev(2)
inc = oev(3)
argper = oev(4)
raan = oev(5)
tanom = oev(6)
slr = sma * (1.0 - ecc * ecc)
rm = slr / (1.0 + ecc * cos(tanom))
arglat = argper + tanom
sarglat = sin(arglat)
carglat = cos(arglat)
c4 = sqr(mu / slr)
c5 = ecc * cos(argper) + carglat
c6 = ecc * sin(argper) + sarglat
sinc = sin(inc)
cinc = cos(inc)
sraan = sin(raan)
craan = cos(raan)
' position vector
r(1) = rm * (craan * carglat - sraan * cinc * sarglat)
r(2) = rm * (sraan * carglat + cinc * sarglat * craan)
r(3) = rm * sinc * sarglat
' velocity vector
v(1) = -c4 * (craan * c6 + sraan * cinc * c5)
v(2) = -c4 * (sraan * c6 - craan * cinc * c5)
v(3) = c4 * c5 * sinc
end sub
sub oeprint(mu, oev())
' print classical orbital elements subroutine
if (oev(1) > 0.0) then
tau = pi2 * sqr(oev(1) * oev(1) * oev(1) / mu)
else
tau = 0.0
end if
print "semimajor axis ", str$(oev(1), 0, 4), " kilometers"
print "eccentricity ", str$(oev(2), 0, 10)
print "orbital inclination ", str$(rtd * oev(3), 0, 4), " degrees"
print "argument of perigee ", str$(rtd * oev(4), 0, 4), " degrees"
print "RAAN ", str$(rtd * oev(5), 0, 4), " degrees"
print "true anomaly ", str$(rtd * oev(6), 0, 4), " degrees"
print " "
print "orbital period ", str$(tau / 60.0, 0, 4), " minutes"
end sub
sub svprint(r(), v())
' print position and velocity vectors subroutine
local rmag, vmag
print "position vector x-component ", str$(r(1), 0, 6), " kilometers"
print "position vector y-component ", str$(r(2), 0, 6), " kilometers"
print "position vector z-component ", str$(r(3), 0, 6), " kilometers"
rmag = vecmag(r())
print " "
print "position vector magnitude ", str$(rmag, 0, 6), " kilometers"
print " "
print "velocity vector x-component ", str$(v(1), 0, 10), " kilometers/second"
print "velocity vector y-component ", str$(v(2), 0, 10), " kilometers/second"
print "velocity vector z-component ", str$(v(3), 0, 10), " kilometers/second"
vmag = vecmag(v())
print " "
print "velocity vector magnitude ", str$(vmag, 0, 10), " kilometers/second"
end sub
function modulo(x) as float
' modulo 2 pi function
local a
a = x - pi2 * fix(x / pi2)
if (a < 0.0) then
a = a + pi2
end if
modulo = a
end function
function atan3(a, b) as float
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' atan3 = angle (0 =< atan3 <= 2 * pi; radians)
local c
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
function vecmag(a()) as float
' vector magnitude function
' input
' { a } = column vector ( 3 rows by 1 column )
' output
' vecmag = scalar magnitude of vector { a }
vecmag = sqr(a(1) * a(1) + a(2) * a(2) + a(3) * a(3))
end function
sub uvector (a(), b())
' unit vector subroutine
' input
' a = column vector (3 rows by 1 column)
' output
' b = unit vector (3 rows by 1 column)
local amag
amag = vecmag(a())
for i% = 1 to 3
if (amag <> 0.0) then
b(i%) = a(i%) / amag
else
b(i%) = 0.0
end if
next i%
end sub
function vdot(a(), b()) as float
' vector dot product function
' c = { a } dot { b }
' input
' n% = number of rows
' { a } = column vector with n rows
' { b } = column vector with n rows
' output
' vdot = dot product of { a } and { b }
local c = 0.0
for i% = 1 to 3
c = c + a(i%) * b(i%)
next i%
vdot = c
end function
sub vcross(a(), b(), c())
' vector cross product subroutine
' { c } = { a } x { b }
' input
' { a } = vector a ( 3 rows by 1 column )
' { b } = vector b ( 3 rows by 1 column )
' output
' { c } = { a } x { b } ( 3 rows by 1 column )
c(1) = a(2) * b(3) - a(3) * b(2)
c(2) = a(3) * b(1) - a(1) * b(3)
c(3) = a(1) * b(2) - a(2) * b(1)
end sub
Here's a PDF note that helps illustrate the geometry of orbital elements.
2017-03-27_180113_orbital_elements.pdf
Other MMBASIC programs and documents can be found at my Google Drive site
https://drive.google.com/drive/folders/0Bx2YPzS0EoweUFR6ZHZ0cVpFWjA?usp=sharing
Posted: 12:06pm 27 Mar 2017
I had a programmable calculator that had a program for the Runge-Kutta method.
I still have the manuals with the program 'somewhere'
I also converted it to an early version of Basic (not MMBasic) many moons ago.
All your submissions are siring many memories.
crez
Posted: 01:48am 28 Mar 2017
I thought this sounded familiar, so dug out my copy of Applied Numerical Analysis by Gerald and Wheatley. It doesn't get opened that often these days.
