Forum Index : Microcontroller and PC projects : MMX - Sun and inner planet ephemeris
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 269 |
This post describes an MMBASIC double precision computer program called ephem1.bas that can be used to create an accurate ephemeris of the sun and inner planets (Mercury, Venus, Earth and Mars). A classical ephemeris consists of tables of sun and planet coordinates at periodic or special times or events. This program provides the rectangular position vectors in both the heliocentric and geocentric coordinate systems. It also provides the Earth-centered-inertial (ECI) right ascension and declination of the sun and other planets. Here's a typical user interaction with ephem1.bas. Notice that all components of position vectors are in the measure of astronomical units (1 AU = 149597870.691 kilometers). please input the calendar date (month [1 - 12], day [1 - 31], year [yyyy]) < for example, october 21, 1986 is input as 10,21,1986 > < b.c. dates are negative, a.d. dates are positive > < the day of the month may also include a decimal part > ? 4,8,2017 please input the UTC time (hours [0 - 24], minutes [0 - 60], seconds [0 - 60]) ? 12,38,0 calendar date April 8 2017 UTC time 12 hours 38 minutes -0.00 seconds UTC Julian day 2457852.02638889 Mercury right ascension 2.0902 hours declination 16.0788 degrees geocentric position vector and magnitude (au) 0.5910612117 0.3601222867 0.1994953608 0.7203053637 heliocentric position vector and magnitude (au) -0.3564973767 0.0630215621 0.0707132033 0.3688664447 Venus right ascension 23.7115 hours declination 4.6409 degrees geocentric position vector and magnitude (au) 0.3088187367 -0.0233674132 0.0251406296 0.3107202907 heliocentric position vector and magnitude (au) -0.6387398517 -0.3204681377 -0.1036415279 0.7221010957 Sun/Earth right ascension 1.1606 hours declination 7.3891 degrees heliocentric position vector and magnitude (au) -0.9475585887 -0.2971007247 -0.1287821575 1.0013595570 Mars right ascension 3.2296 hours declination 18.4480 degrees geocentric position vector and magnitude (au) 1.4313507217 1.6146954787 0.7198071077 2.2746711077 heliocentric position vector and magnitude (au) 0.4837921337 1.3175947537 0.5910249507 1.5229646277 Here's a PDF document that illustrates several ephemeris algorithms. 2017-04-08_195205_ephemeris.pdf The following is the MMBASIC source code listing for this computer program. ' program ephem1.bas April 8, 2017 ' sun and inner planet ephemeris ' Special thanks to Pierre Bretagnon and Jean-Louis Simon ' for developing their eloquent planetary ephemeris. ' "Planetary Programs and Tables from -4000 to +2800" ''''''''''''''''''''''''''''''''''''''''''''''''''''' option default float option base 1 const pi2 = 2.0 * pi, pidiv2 = 0.5 * pi, rtd = 180.0 / pi, dtr = pi / 180.0 dim body$(4), month$(12) dim rsun(3), rpg(3), rph(3), jdleap(28), leapsec(28) dim sl(50), sr(50), sa(50), sb(50), cl(184), al(184), bl(184) dim ibody%, utc_hr, utc_min, utc_sec, cmonth, cday, cyear ' read sun and planet data read_data ' request epoch of interest getdate (cmonth, cday, cyear) ' UTC julian day julian(cmonth, cday, cyear, jdutc) getutc(utc_hr, utc_min, utc_sec) jdutc = jdutc + utc_hr / 24.0 + utc_min / 1440.0 + utc_sec / 86400.0 ' TDB julian day utc2tdb(jdutc, jdtdb) print " " print " " jd2str(jdutc) print " " print "UTC Julian day ", str$(jdutc, 0, 8) print " " ' calculate and display ephemeris for each ody for ibody% = 1 to 4 ephem(ibody%, jdtdb, rpg(), rph(), rasc, decl) print " " print body$(ibody%) print " " print "right ascension ", str$(24.0 * (rasc / pi2), 0, 4), " hours" print " " print "declination ", str$(rtd * decl, 0, 4), " degrees" print " " if (ibody% <> 3) then print "geocentric position vector and magnitude (au)" print " " print str$(rpg(1), 0, 10), " ", str$(rpg(2), 0, 10), " ", str$(rpg(3), 0, 10), " ", str$(vecmag(rpg()), 0, 10) print " " end if print "heliocentric position vector and magnitude (au)" print " " print str$(rph(1), 0, 10), " ", str$(rph(2), 0, 10), " ", str$(rph(3), 0, 10), " ", str$(vecmag(rph()), 0, 10) print " " next ibody% end '''''''''''''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''''''''''''''''''' sub ephem(ibody%, jdtdb, rpg(), rph(), rasc, decl) ' sun and inner planet ephemeris subroutine ' input ' ibody% = celestial body index ' jdtdb = tdb julian day ' output ' rpg() = geocentric position vector (au) ' rph() = heliocentric position vector (au) ' rasc = geocentric right ascension (radians) ' decl = geocentric declination (radians) ''''''''''''''''''''''''''''''''''''''''''' local dls, drs, gl, gb, pl, pb, pr, alon, alat ' compute coordinates of the sun sun(jdtdb, dls, drs, rasun, decsun, rsun()) gl = dls ' compute coordinates of the planet select case ibody% case 1 mercury(jdtdb, pl, pb, pr) case 2 venus(jdtdb, pl, pb, pr) case 3 ' sun/earth for i% = 1 to 3 rph(i%) = -rsun(i%) rpg(i%) = 0.0 next i% rasc = rasun decl = decsun exit sub case 4 mars(jdtdb, pl, pb, pr) end select ' compute geocentric mean coordinates latlong(dls, drs, pl, pb, pr, gl, gb, rpgm) ' apparent geocentric equatorial right ascension and declination abernu(jdtdb, ibody%, gl, gb, alon, alat, rasc, decl) ' compute geocentric equatorial unit position vector of planet rpg(1) = rpgm * cos(rasc) * cos(decl) rpg(2) = rpgm * sin(rasc) * cos(decl) rpg(3) = rpgm * sin(decl) ' compute geocentric equatorial position vector for i% = 1 to 3 rph(i%) = rpg(i%) - rsun(i%) next i% end sub ''''''''''''''''''''''''''''''''''''''''''' ''''''''''''''''''''''''''''''''''''''''''' sub latlong(sl, sr, pl, pb, pr, gl, gb, rpgm) ' geocentric mean coordinates subroutine '''''''''''''''''''''''''''''''''''''''' local xs, ys, xp, yp, zp, x, y, z ' heliocentric ecliptic position of the sun xs = sr * cos(sl) ys = sr * sin(sl) ' heliocentric ecliptic position of planet xp = pr * cos(pb) * cos(pl) yp = pr * cos(pb) * sin(pl) zp = pr * sin(pb) ' geocentric ecliptic position of planet x = xp + xs y = yp + ys z = zp ' mean geocentric longitude of planet (radians) gl = atan3(y, x) ' mean geocentric latitude of planet (radians) gb = atan2(z, sqr(x^2 + y^2)) ' geocentric distance of planet rpgm = sqr(x * x + y * y + z * z) end sub ''''''''''''''''''''''''''''''''''''''''''''''''''''''' ''''''''''''''''''''''''''''''''''''''''''''''''''''''' sub abernu(jdtdb, ibody%, gl, gb, alon, alat, rasc, decl) ' aberration and nutation corrections subroutine '''''''''''''''''''''''''''''''''''''''''''''''' local u, a1, a2, dpsi, deps, epsi local xce, xse, xcl, xsl, xcb, xsb ' fundamental time argument u = (jdtdb - 2451545.0) / 3652500.0 select case ibody% case 1 ' mercury alon = gl + 0.0000001 * (-1261.0 + 1485.0 * cos(2.649 + 198048.273 * u)) alon = alon + 0.0000001 * (305.0 * cos(5.71 + 458927.03 * u) + 230.0 * cos(5.3 + 396096.55 * u)) alat = gb + 0.000019 * cos(0.42 + 260879.41 * u) case 2 ' venus alon = gl + 0.0000001 * (-1304.0 + 1016.0 * cos(1.423 + 39302.097 * u)) alon = alon + 0.0000001 * (224.0 * cos(2.85 + 78604.19 * u) + 98.0 * cos(4.27 + 117906.29 * u)) alat = gb case 3 ' earth alon = gl + 0.0000001 * (-993.0 + 17.0 * cos(3.1 + 62830.14 * u)) alat = 0.0 case 4 ' mars alon = gl + 0.0000001 * (-1052.0 + 877.0 * cos(1.834 + 29424.634 * u)) alon = alon + 0.0000001 * (187.0 * cos(3.67 + 58849.27 * u) + 84.0 * cos(3.49 + 33405.34 * u)) alat = gb end select ' nutation corrections a1 = 2.18 + u * (-3375.7 + u * 0.36) a2 = 3.51 + u * (125666.39 + u * 0.1) dpsi = 0.0000001 * (-834.0 * sin(a1) - 64.0 * sin(a2)) deps = 0.0000001 * u * (-226938.0 + u * (-75.0 + u * (96926.0 + u * (-2491.0 - u * 12104.0)))) epsi = 0.0000001 * (4090928.0 + 446.0 * cos(a1) + 28.0 * cos(a2)) + deps alon = modulo(alon + dpsi) ' compute right ascension and declination (radians) xce = cos(epsi) xse = sin(epsi) xcl = cos(alon) xsl = sin(alon) xcb = cos(alat) xsb = sin(alat) decl = asin(xce * xsb + xse * xcb * xsl) rasc = atan3(-xse * xsb + xce * xcb * xsl, xcb * xcl) end sub '''''''''''''''''''''''''''' '''''''''''''''''''''''''''' sub mercury(jdtdb, pl, pb, pr) ' computation of the heliocentric coordinates of mercury ''''''''''''''''''''''''''''''''''''''''''''''''''''''''' local u, h1, w1 u = (jdtdb - 2451545.0) / 3652500.0 pl = 0.0 for i% = 1 to 25 pl = pl + cl(i%) * sin(al(i%) + bl(i%) * u) next i% pl = pl * 0.0000001 + 4.4429839 + u * 260881.4701279 h1 = 0.000001 * (409894.2 + u * (2435.0 + u * (-1408.0 + u * (114.0 + u * (233.0 - u * 88.0))))) w1 = 3.053817 + u * (260878.756773 + u * (-0.001093 + u * (-9.3e-04 + u * (0.00043 + u * 0.00014)))) pl = modulo(pl + h1 * sin(w1)) pb = 0.0 for i% = 26 to 43 pb = pb + cl(i%) * sin(al(i%) + bl(i%) * u) next i% pb = pb * 0.0000001 pr = 0.0 for i% = 44 to 57 pr = pr + cl(i%) * cos(al(i%) + bl(i%) * u) next i% pr = pr * 0.0000001 + 0.395202 end sub '''''''''''''''''''''''''' '''''''''''''''''''''''''' sub venus(jdtdb, pl, pb, pr) ' computation of the heliocentric coordinates of venus ''''''''''''''''''''''''''''''''''''''''''''''''''''''' local u, t1, h1, t2, w1, t3, h2, w2, t4 u = (jdtdb - 2451545.0) / 3652500.0 pl = 0.0 for i% = 58 to 77 pl = pl + cl(i%) * sin(al(i%) + bl(i%) * u) next i% pl = pl * 0.0000001 + 3.2184413 + u * 102135.2937764 t1 = -51.0 + u * 10.0 h1 = 0.000001 * (13539.7 + u * (-9570.0 + u * (1987.0 + u * (927.0 + u * (230.0 + u * t1))))) t2 = 0.0017 + u * 0.0151 w1 = 0.88074 + u * (102132.84648 + u * (0.24082 + u * (0.1004 + u * (0.0355 - u * t2)))) t3 = -79.0 + u * 56.0 h2 = 0.000001 * (898.9 + u * (112.4 + u * (-170.0 + u * (113.0 + u * (34.0 + u * t3))))) w2 = 0.5941 + u * (204267.313 + u * (0.014 + u * (0.123 + u * (-0.146 + u * 0.052)))) pl = modulo(pl + h1 * sin(w1) + h2 * sin(w2)) pb = 0.0 for i% = 78 to 83 pb = pb + cl(i%) * sin(al(i%) + bl(i%) * u) next i% h1 = 0.0000001 * (4011.0 + u * (-2713.0 + u * (490.0 + u * (290.0 + u * 90.0)))) w1 = 2.7182 + u * (204266.568 + u * (0.225 + u * (0.102 + u * 0.035))) h2 = 0.0000001 * (101.0 + u * (26.0 - u * 64.0)) w2 = 2.66 + u * (306400.49 + u * 0.45) pb = pb * 0.0000001 + h1 * sin(w1) + h2 * sin(w2) pr = 0.0 for i% = 84 to 88 pr = pr + cl(i%) * cos(al(i%) + bl(i%) * u) next i% pr = pr * 0.0000001 + 0.7235481 h1 = 0.0000001 * (48982.0 + u * (-34549.0 + u * (7096.0 + u * (3360.0 + u * (890.0 - u * 210.0))))) t4 = -0.0013 - u * 0.015 w1 = 4.02152 + u * (102132.84695 + u * (0.242 + u * (0.0994 + u * (0.0351 + u * t4)))) h2 = 0.0000001 * (166.0 + u * (-234.0 + u * 131.0)) w2 = 4.9 + u * (204265.69 + u * (0.48 + u * 0.2)) pr = pr + h1 * cos(w1) + h2 * cos(w2) end sub ''''''''''''''''''''''''' ''''''''''''''''''''''''' sub mars(jdtdb, pl, pb, pr) ' computation of the heliocentric coordinates of mars '''''''''''''''''''''''''''''''''''''''''''''''''''''' local u, h1, h2, h3, w1, w3, w2 local t5, t6, t7, t8, t9, t10, t11 u = (jdtdb - 2451545.0) / 3652500.0 ' longitude pl = 0.0 for i% = 89 to 148 pl = pl + cl(i%) * sin(al(i%) + bl(i%) * u) next i% pl = pl * 0.0000001 + 6.2458611 + 33408.5620646 * u h1 = 0.000001 * (186563.7 + u * (18135.0 + u * (-1332.0 + u * (-704.0 + u * (-65.0 - u * 89.0))))) t5 = 290.0 + u * 100.0 w1 = 0.337967 + u * (33405.348759 + 0.000001 * u * (31676.0 - u * (7354.0 - u * (1143.0 - u * t5)))) pl = modulo(pl + h1 * sin(w1)) ' latitude pb = 0.0 for i% = 149 to 155 pb = pb + cl(i%) * sin(al(i%) + bl(i%) * u) next i% t6 = 5310.0 - u * 1050.0 h1 = u * (-10277.0 + u * (24272.0 + u * (-2420.0 + u * (-10850.0 + u * (3880.0 + u * t6))))) h1 = 0.0000001 * (319714.0 + h1) w1 = u * (0.048 + u * (-0.04831 + u * (0.01402 + u * (0.029 + u * (-0.0073 - u * 0.0112))))) w1 = 5.339102 + u * (33407.21879 + w1) t7 = 220.0 + u * 270.0 h2 = 0.0000001 * (29803.0 + u * (1904.0 + u * (1865.0 + u * (-60.0 + u * (-950.0 + u * t7))))) w2 = 5.67694 + u * (66812.5668 + u * (0.08030001 + u * (-0.0536.0 + u * (0.0147 + u * 0.028)))) h3 = 0.0000001 * (3137.0 + u * (472.0 + u * (111.0 + u * 70.0))) w3 = 6.0173 + u * (100217.928 + u * (0.093 + u * (-8.6e-02 + u * 0.037))) pb = pb * 0.0000001 + h1 * sin(w1) + h2 * sin(w2) + h3 * sin(w3) ' radius pr = 0.0 for i% = 156 to 184 pr = pr + cl(i%) * cos(al(i%) + bl(i%) * u) next i% pr = pr * 0.0000001 + 1.529856 t8 = -153.0 - u * 73.0 h1 = 0.000001 * (141849.5 + u * (13651.8 + u * (-1230.0 + u * (-378.0 + u * (187.0 + u * t8))))) t9 = 83.0 - u * 48.0 w1 = 3.479698 + u * (33405.34956 + 0.00001 * (u * (3066.9 + u * (-909.0 + u * (223.0 + u * t9))))) t10 = -12.0 + u * 99.0 h2 = 0.000001 * (6607.8 + u * (1272.8 + u * (-53.0 + u * (-46.0 + u * (14.0 + u * t10))))) t11 = 0.0012 + u * 0.002 w2 = 3.81781 + u * (66810.6991 + u * (0.0613 + u * (-0.0182 + u * (0.0044 + u * t11)))) pr = pr + h1 * cos(w1) + h2 * cos(w2) end sub '''''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''''''''''' sub sun(jdtdb, dl, dr, rasc, decl, rsun()) ' precision ephemeris of the Sun ' input ' jdtdb = julian ephemeris day ' output ' dl = ecliptic longitude of the sun (radians) ' (0 <= dl <= 2 pi) ' dr = geocentric distance of the sun (AU) ' rasc = right ascension of the Sun (radians) ' (0 <= rasc <= 2 pi) ' decl = declination of the Sun (radians) ' (-pi/2 <= decl <= pi/2) ''''''''''''''''''''''''''''''''' local u, a1, a2, psi, deps, meps, eps, seps, ceps local w, srl, crl, srb, crb, sra, cra u = (jdtdb - 2451545.0) / 3652500.0 ' compute nutation in longitude a1 = 2.18 + u * (-3375.7 + u * 0.36) a2 = 3.51 + u * (125666.39 + u * 0.1) psi = 0.0000001 * (-834.0 * sin(a1) - 64.0 * sin(a2)) ' compute nutation in obliquity deps = 0.0000001 * u * (-226938 + u * (-75 + u * (96926 + u * (-2491 - u * 12104)))) meps = 0.0000001 * (4090928.0 + 446.0 * cos(a1) + 28.0 * cos(a2)) eps = meps + deps obliq = eps seps = sin(eps) ceps = cos(eps) dl = 0.0 dr = 0.0 for i% = 1 to 50 w = sa(i%) + sb(i%) * u dl = dl + sl(i%) * sin(w) if (sr(i%) <> 0.0) then dr = dr + sr(i%) * cos(w) end if next i% dl = modulo(dl * 0.0000001 + 4.9353929 + 62833.196168 * u) dr = dr * 0.0000001 + 1.0001026 rlsun = modulo(dl + 0.0000001 * (-993.0 + 17.0 * cos(3.1 + 62830.14 * u)) + psi) rb = 0.0 ' compute geocentric declination and right ascension crl = cos(rlsun) srl = sin(rlsun) crb = cos(rb) srb = sin(rb) decl = asin(ceps * srb + seps * crb * srl) sra = -seps * srb + ceps * crb * srl cra = crb * crl rasc = atan3(sra, cra) ' geocentric equatorial position vector of the Sun (kilometers) rsun(1) = dr * cos(rasc) * cos(decl) rsun(2) = dr * sin(rasc) * cos(decl) rsun(3) = dr * sin(decl) end sub '''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''' sub julian(month, day, year, jday) ' Gregorian date to julian day subroutine ' input ' month = calendar month ' day = calendar day ' year = calendar year (all four digits) ' output ' jday = julian day ' special notes ' (1) calendar year must include all digits ' (2) will report October 5, 1582 to October 14, 1582 ' as invalid calendar dates and exit ''''''''''''''''''''''''''''''''''''''''' local a, b, c, m, y y = year m = month b = 0.0 c = 0.0 if (m <= 2.0) then y = y - 1.0 m = m + 12.0 end if if (y < 0.0) then c = -0.75 if (year < 1582.0) then ' null elseif (year > 1582.0) then a = fix(y / 100.0) b = 2.0 - a + fix(a / 4.0) elseif (month < 10.0) then ' null elseif (month > 10.0) then a = fix(y / 100.0) b = 2.0 - a + fix(a / 4.0) elseif (day <= 4.0) then ' null elseif (day > 14.0) then a = fix(y / 100.0) b = 2.0 - a + fix(a / 4.0) else print "this date does not exist!!" exit end if jday = fix(365.25 * y + c) + fix(30.6001 * (m + 1.0)) + day + b + 1720994.5 end sub '''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''' sub gdate (jday, month, day, year) ' Julian day to Gregorian date subroutine ' input ' jday = julian day ' output ' month = calendar month ' day = calendar day ' year = calendar year '''''''''''''''''''''''' local a, b, c, d, e, f, z, alpha z = fix(jday + 0.5) f = jday + 0.5 - z if (z < 2299161) then a = z else alpha = fix((z - 1867216.25) / 36524.25) a = z + 1.0 + alpha - fix(alpha / 4.0) end if b = a + 1524.0 c = fix((b - 122.1) / 365.25) d = fix(365.25 * c) e = fix((b - d) / 30.6001) day = b - d - fix(30.6001 * e) + f if (e < 13.5) then month = e - 1.0 else month = e - 13.0 end if if (month > 2.5) then year = c - 4716.0 else year = c - 4715.0 end if end sub '''''''''''''''''''''''' '''''''''''''''''''''''' sub utc2tdb (jdutc, jdtdb) ' convert UTC julian date to TDB julian date ' input ' jdutc = UTC julian day ' output ' jdtdb = TDB julian day ' Reference Frames in Astronomy and Geophysics ' J. Kovalevsky et al., 1989, pp. 439-442 ''''''''''''''''''''''''''''''''''''''''' local corr, jdtt, t, leapsecond ' find current number of leap seconds findleap(jdutc, leapsecond) ' compute TDT julian date corr = (leapsecond + 32.184) / 86400.0 jdtt = jdutc + corr ' time argument for correction t = (jdtt - 2451545.0) / 36525.0 ' compute correction in microseconds corr = 1656.675 * sin(dtr * (35999.3729 * t + 357.5287)) corr = corr + 22.418 * sin(dtr * (32964.467 * t + 246.199)) corr = corr + 13.84 * sin(dtr * (71998.746 * t + 355.057)) corr = corr + 4.77 * sin(dtr * ( 3034.906 * t + 25.463)) corr = corr + 4.677 * sin(dtr * (34777.259 * t + 230.394)) corr = corr + 10.216 * t * sin(dtr * (35999.373 * t + 243.451)) corr = corr + 0.171 * t * sin(dtr * (71998.746 * t + 240.98 )) corr = corr + 0.027 * t * sin(dtr * ( 1222.114 * t + 194.661)) corr = corr + 0.027 * t * sin(dtr * ( 3034.906 * t + 336.061)) corr = corr + 0.026 * t * sin(dtr * ( -20.186 * t + 9.382)) corr = corr + 0.007 * t * sin(dtr * (29929.562 * t + 264.911)) corr = corr + 0.006 * t * sin(dtr * ( 150.678 * t + 59.775)) corr = corr + 0.005 * t * sin(dtr * ( 9037.513 * t + 256.025)) corr = corr + 0.043 * t * sin(dtr * (35999.373 * t + 151.121)) ' convert corrections to days corr = 0.000001 * corr / 86400.0 ' TDB julian date jdtdb = jdtt + corr end sub ''''''''''''''' ''''''''''''''' sub jd2str(jdutc) ' convert julian day to calendar date and UTC time '''''''''''''''''''''''''''''''''''''''''''''''''' gdate (jdutc, cmonth, day, year) print "calendar date ", month$(cmonth); " ", STR$(int(day)); " "; str$(year) print " " thr0 = 24.0 * (day - int(day)) thr = int(thr0) tmin0 = 60.0 * (thr0 - thr) tmin = int(tmin0) tsec = 60.0 * (tmin0 - tmin) ' fix seconds and minutes for rollover if (tsec >= 60.0) then tsec = 0.0 tmin = tmin + 1.0 end if ' fix minutes for rollover if (tmin >= 60.0) then tmin = 0.0 thr = thr + 1.0 end if print "UTC time ", str$(thr) + " hours " + str$(tmin) + " minutes " + str$(tsec, 0, 2) + " seconds" end sub '''''''''''''''''''''''''''' '''''''''''''''''''''''''''' sub findleap(jday, leapsecond) ' find number of leap seconds for utc julian day ' input ' jday = utc julian day ' input via global ' jdleap = array of utc julian dates ' leapsec = array of leap seconds ' output ' leapsecond = number of leap seconds '''''''''''''''''''''''''''''''''''''' if (jday <= jdleap(1)) then ' date is <= 1972; set to first data element leapsecond = leapsec(1) exit sub end if if (jday >= jdleap(28)) then ' date is >= end of current data ' set to last data element leapsecond = leapsec(28) exit sub end if ' find data within table for i% = 1 to 27 if (jday >= jdleap(i%) and jday < jdleap(i% + 1)) then leapsecond = leapsec(i%) exit sub end if next i% end sub ''''''''''''''''''''''''' ''''''''''''''''''''''''' function modulo(x) as float ' modulo 2 pi function '''''''''''''''''''''' local a a = x - pi2 * fix(x / pi2) if (a < 0.0) then a = a + pi2 end if modulo = a end function ''''''''''''''''''''''''''' ''''''''''''''''''''''''''' function atan3(a, b) as float ' four quadrant inverse tangent function ' input ' a = sine of angle ' b = cosine of angle ' output ' atan3 = angle (0 =< atan3 <= 2 * pi; radians) '''''''''''''''''''''''''''''''''''''''''''''''' local c if (abs(a) < 1.0e-10) then atan3 = (1.0 - sgn(b)) * pidiv2 exit function else c = (2.0 - sgn(a)) * pidiv2 endif if (abs(b) < 1.0e-10) then atan3 = c exit function else atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2) endif end function ''''''''''' ''''''''''' sub read_data ' read sun and planet data subroutine ''''''''''''''''''''''''''''''''''''' for i% = 1 to 4 read body$(i%) next i% for i% = 1 to 50 read sl(i%), sr(i%), sa(i%), sb(i%) next i% for i% = 1 to 184 read cl(i%), al(i%), bl(i%) next i% data "Mercury","Venus","Sun/Earth","Mars" ' data for the sun - longitude and radius vector data 403406, 0, 4.721964, 1.621043 data 195207, -97597, 5.937458, 62830.348067 data 119433, -59715, 1.115589, 62830.821524 data 112392, -56188, 5.781616, 62829.634302 data 3891, -1556, 5.5474 , 125660.5691 data 2819, -1126, 1.5120 , 125660.9845 data 1721, -861, 4.1897 , 62832.4766 data 0, 941, 1.163 , 0.813 data 660, -264, 5.415 , 125659.310 data 350, -163, 4.315 , 57533.850 data 334, 0, 4.553 , -33.931 data 314, 309, 5.198 , 777137.715 data 268, -158, 5.989 , 78604.191 data 242, 0, 2.911 , 5.412 data 234, -54, 1.423 , 39302.098 data 158, 0, 0.061 , -34.861 data 132, -93, 2.317 , 115067.698 data 129, -20, 3.193 , 15774.337 data 114, 0, 2.828 , 5296.670 data 99, -47, 0.52 , 58849.27 data 93, 0, 4.65 , 5296.11 data 86, 0, 4.35 , -3980.70 data 78, -33, 2.75 , 52237.69 data 72, -32, 4.50 , 55076.47 data 68, 0, 3.23 , 261.08 data 64, -10, 1.22 , 15773.85 data 46, -16, 0.14 , 188491.03 data 38, 0, 3.44 , -7756.55 data 37, 0, 4.37 , 264.89 data 32, -24, 1.14 , 117906.27 data 29, -13, 2.84 , 55075.75 data 28, 0, 5.96 , -7961.39 data 27, -9, 5.09 , 188489.81 data 27, 0, 1.72 , 2132.19 data 25, -17, 2.56 , 109771.03 data 24, -11, 1.92 , 54868.56 data 21, 0, 0.09 , 25443.93 data 21, 31, 5.98 , -55731.43 data 20, -10, 4.03 , 60697.74 data 18, 0, 4.27 , 2132.79 data 17, -12, 0.79 , 109771.63 data 14, 0, 4.24 , -7752.82 data 13, -5, 2.01 , 188491.91 data 13, 0, 2.65 , 207.81 data 13, 0, 4.98 , 29424.63 data 12, 0, 0.93 , -7.99 data 10, 0, 2.21 , 46941.14 data 10, 0, 3.59 , -68.29 data 10, 0, 1.50 , 21463.25 data 10, -9, 2.55 , 157208.40 ' data for mercury - heliocentric longitude, latitude and radius vector data 510728, 6.09670 , 521757.52364 , 404847, 4.72189, 1.62027 data 91048, 2.8946 , 782636.2744 , 30594, 4.1535 , 521758.6270 data 15769, 5.8003 , 1043515.073 , 13726, 0.4656 , 521756.9570 data 11582, 1.0266 , 782637.2016 , 7633, 3.517 , 521759.335 data 5247, 0.418 , 782638.007 , 4001, 3.993 , 1043516.352 data 3299, 2.791 , 1304393.680 , 3212, 0.209 , 1043514.724 data 1690, 2.067 , 1304394.627 , 1482, 6.174 , 1304395.168 data 1233, 3.606 , 782635.409 , 1152, 5.856 , 1565272.646 data 845, 2.63 , 1043516.88 , 654, 3.40 , 1565273.50 data 359, 2.66 , 1826151.56 , 356, 3.08 , 11094.77 data 257, 6.27 , 1826152.20 , 246, 2.89 , 5.41 data 180, 5.67 , 56613.61 , 159, 4.57 , 250285.49 data 137, 6.17 , 271973.50 data 680303, 3.82625 , 260879.17693 , 538354, 3.30009, 260879.66625 data 176935, 3.74070 , 0.40005 , 143323, 0.58073, 521757.92658 data 105214, 0.0545 , 521758.44880 , 91011, 3.3915 , 0.9954 data 47427, 1.9266 , 260878.2610 , 41669, 3.5084 , 782636.7624 data 19826, 3.1539 , 782637.4813 , 12963, 0.2455 , 1043515.6610 data 8233, 4.886 , 521756.972 , 6399, 0.358 , 782637.769 data 3196, 3.253 , 1304394.380 , 1536, 4.824 , 1043516.451 data 824, 0.04 , 1565273.15 , 819, 1.84 , 782635.45 data 324, 1.60 , 1304395.53 , 201, 2.92 , 1826151.86 data 780141, 6.202782, 260878.753962, 78942, 2.98062, 521757.50830 data 12000, 6.0391 , 782636.2640 , 9839, 4.8422 , 260879.3808 data 2355, 5.062 , 0.734 , 2019, 2.898 , 1043514.987 data 1974, 1.588 , 521758.140 , 1859, 0.805 , 260877.716 data 426, 4.601 , 782636.915 , 397, 5.976 , 1304393.735 data 382, 3.86 , 521756.47 , 306, 1.87 , 1043515.34 data 102, 0.62 , 782635.28 , 92, 2.60 , 1565272.52 ' data for venus - heliocentric longitude, latitude and radius vector data 423015, 4.722173, 1.600752, 548 , 5.987 , 78604.195 data 346, 4.27 , 117906.29 , 253 , 2.95 , 5.37 data 237, 4.56 , 39302.10 , 181 , 0.05 , 15774.33 data 153, 2.14 , 306400.25 , 144 , 5.73 , 96835.94 data 99, 0.09 , 261.08 , 98 , 6.18 , 306399.50 data 89, 4.34 , 15773.85 , 85 , 2.86 , 94378.51 data 69, 2.85 , 5296.67 , 56 , 5.71 , 1915.95 data 55, 1.23 , 264.89 , 55 , 2.85 , 7756.55 data 50, 5.69 , 157208.38 , 48 , 4.62 , 5296.12 data 43, 5.16 , 193671.89 , 39 , 0.85 , 94377.98 data 590350, 1.759897, 102133.735253, 34737, 3.17478, 102133.01934 data 13104, 0.2705 , 2.0678 , 12910, 3.7446 , 102134.2721 data 8591, 3.7878 , 1.5631 , 7015, 3.3730 , 2.2248 data 2101, 2.828 , 0.361 , 163, 2.85 , 78604.20 data 138, 1.13 , 117906.29 , 50, 2.59 , 96835.94 data 37, 1.42 , 39302.10 ' data for mars - heliocentric longitude, latitude and radius vector data 424067, 4.725053, 1.599646 , 117053, 0.92177, 66810.71641 data 31286, 5.17451 , 66811.55202 , 10248, 1.3885 , 100216.0920 data 4933, 1.4302 , 66813.4604 , 4130, 5.4976 , 100216.8648 data 2605, 1.382 , -33.896 , 1334, 3.104 , -34.791 data 1232, 2.420 , 28109.218 , 1180, 2.148 , 133621.421 data 959, 4.404 , 22813.140 , 827, 6.053 , 133621.745 data 778, 4.910 , 56218.431 , 692, 1.881 , 100218.894 data 667, 1.267 , -3980.684 , 416, 1.799 , 29424.634 data 354, 3.146 , 25443.942 , 341, 1.005 , 66815.503 data 339, 1.420 , 33371.351 , 310, 0.916 , -33439.371 data 294, 2.57 , 1915.95 , 260, 2.69 , -7961.45 data 245, 3.70 , 33370.81 , 242, 2.94 , 5.41 data 198, 2.78 , 5296.69 , 182, 3.09 , -33440.09 data 167, 4.28 , 17516.29 , 153, 2.72 , 61514.60 data 148, 5.27 , 22812.71 , 141, 4.51 , 21463.18 data 128, 1.06 , 100220.45 , 126, 5.19 , 50921.57 data 105, 0.77 , 5296.06 , 103, 5.26 , 89623.78 data 86, 3.97 , 29140.97 , 81, 5.38 , 1559.53 data 72, 0.90 , -37386.05 , 71, 5.23 , 10592.20 data 66, 2.06 , 31273.21 , 64, 4.49 , 84327.58 data 63, 1.43 , 167027.36 , 60, 1.77 , 133625.34 data 55, 4.02 , -7.37 , 55, 6.05 , 17482.57 data 47, 4.23 , -11942.07 , 45, 1.23 , 1914.57 data 43, 6.24 , -3981.49 , 43, 2.12 , 62829.99 data 42, 2.07 , 2131.89 , 38, 4.90 , -7962.27 data 36, 0.02 , 17514.95 , 33, 2.37 , 167026.02 data 31, 4.65 , 25443.27 , 31, 2.57 , 66776.76 data 30, 1.19 , -66844.78 , 30, 6.06 , 35321.38 data 30, 4.35 , 62546.28 , 29, 5.79 , 207.81 data 28, 1.17 , 13501.91 , 28, 2.09 , -31489.48 data 32962, 1.67255 , 1.77247 , 9705, 3.5531 , 0.9198 data 367, 0.353 , 133623.307 , 101, 4.74 , 133624.11 data 44, 0.94 , 33373.21 , 44, 2.83 , -33441.23 data 40, 0.42 , 167028.67 data 27946, 4.8846 , 0.4677 , 5147, 4.5968 , 100216.0535 data 2196, 2.568 , 100216.663 , 811, 5.560 , 28109.218 data 749, 1.772 , 56218.430 , 559, 5.112 , 133621.486 data 503, 1.272 , 22813.139 , 332, 2.701 , 133621.941 data 258, 4.56 , 33371.35 , 248, 4.93 , 29424.63 data 236, 0.92 , -33439.37 , 231, 0.09 , 25443.93 data 186, 0.56 , 33370.81 , 138, 3.09 , -33440.09 data 117, 2.11 , 50921.57 , 110, 1.27 , -3980.70 data 99, 5.84 , 61514.59 , 90, 4.41 , 5296.11 data 90, 5.64 , 167026.95 , 81, 2.10 , 10592.24 data 80, 2.83 , -7961.39 , 74, 1.50 , 21463.25 data 73, 1.25 , 84327.62 , 71, 2.86 , 167027.21 data 69, 2.10 , 22812.70 , 69, 2.13 , 89623.77 data 63, 1.29 , 17516.40 , 57, 0.83 , 29140.97 data 53, 0.90 , -37386.04 ' calendar months month$(1) = "January" month$(2) = "February" month$(3) = "March" month$(4) = "April" month$(5) = "May" month$(6) = "June" month$(7) = "July" month$(8) = "August" month$(9) = "September" month$(10) = "October" month$(11) = "November" month$(12) = "December" ' read leap second data for i% = 1 to 28 read jdleap(i%), leapsec(i%) next i% data 2441317.5, 10.0 data 2441499.5, 11.0 data 2441683.5, 12.0 data 2442048.5, 13.0 data 2442413.5, 14.0 data 2442778.5, 15.0 data 2443144.5, 16.0 data 2443509.5, 17.0 data 2443874.5, 18.0 data 2444239.5, 19.0 data 2444786.5, 20.0 data 2445151.5, 21.0 data 2445516.5, 22.0 data 2446247.5, 23.0 data 2447161.5, 24.0 data 2447892.5, 25.0 data 2448257.5, 26.0 data 2448804.5, 27.0 data 2449169.5, 28.0 data 2449534.5, 29.0 data 2450083.5, 30.0 data 2450630.5, 31.0 data 2451179.5, 32.0 data 2453736.5, 33.0 data 2454832.5, 34.0 DATA 2456109.5, 35.0 data 2457204.5, 36.0 data 2457754.5, 37.0 end sub '''''''''''''''''' '''''''''''''''''' function vecmag(a()) ' vector magnitude function ' input ' { a } = column vector ( 3 rows by 1 column ) ' output ' vecmag = scalar magnitude of vector { a } vecmag = sqr(a(1) * a(1) + a(2) * a(2) + a(3) * a(3)) end function '''''''''''''''''''''''''''' '''''''''''''''''''''''''''' sub getdate (month, day, year) ' request calendar date subroutine do print " " print "please input the calendar date" print " " print "(month [1 - 12], day [1 - 31], year [yyyy])" print "< for example, october 21, 1986 is input as 10,21,1986 >" print "< b.c. dates are negative, a.d. dates are positive >" print "< the day of the month may also include a decimal part >" print " " input month, day, year loop until (month >= 1 and month <= 12) and (day >= 1 and day <= 31) end sub '''''''''''''''''''''''''' '''''''''''''''''''''''''' sub getutc (thr, tmin, tsec) ' request time subroutine do print " " print "please input the UTC time" print " " print "(hours [0 - 24], minutes [0 - 60], seconds [0 - 60])" print " " input thr, tmin, tsec loop until ((thr >= 0.0 and thr <= 24.0) and (tmin >= 0.0 and tmin <= 60.0) and (tsec >= 0.0 and tsec <= 60.0)) end sub https://drive.google.com/drive/folders/0Bx2YPzS0EoweUFR6ZHZ0cVpFWjA?usp=sharing |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1147 |
YEAH, THAT'S IT!!!! Thank you very lot for sharing!!! (...and now the outer Planets! )Can you help me? How can I convert the heliocentric position vector to heliocentric coordinates??? THANKS!!! Frank |
What type of heliocentric coordinates do you need to calculate? |
Hi David, thanks for your fast reply! I need the coordinates as ecliptic coordinates, calculated from sun as midpoint with λ – ecliptic longitude from vernal equinox and β – ecliptic latitude... Did you have a explanation (link) for your heliocentric position vector? Thanks! Frank |
Frank, Each planet subroutine provides the ecliptic coordinates you need. For example mars(jdtdb, pl, pb, pr) In the argument list, jdtdb is the barycentric dynamical time (TDB) Julian day, pl is the heliocentric ecliptic longitude in radians, pb is the heliocentric ecliptic latitude in radians and pr is the heliocentric distance in astronomical units. The following subroutine computes the different position vectors. Note that the heliocentric rectangular position vector of the sun and planet are computed from the polar coordinates of the sun (sl, sr) and planet (pl, pb, pr). sub latlong(sl, sr, pl, pb, pr, gl, gb, rpgm) ' geocentric mean coordinates subroutine '''''''''''''''''''''''''''''''''''''''' local xs, ys, xp, yp, zp, x, y, z ' heliocentric ecliptic position of the sun xs = sr * cos(sl) ys = sr * sin(sl) ' heliocentric ecliptic position of planet xp = pr * cos(pb) * cos(pl) yp = pr * cos(pb) * sin(pl) zp = pr * sin(pb) ' geocentric ecliptic position of planet x = xp + xs y = yp + ys z = zp ' mean geocentric longitude of planet (radians) gl = atan3(y, x) ' mean geocentric latitude of planet (radians) gb = atan2(z, sqr(x^2 + y^2)) ' geocentric distance of planet rpgm = sqr(x * x + y * y + z * z) end sub |
Hi David, thank you very much! I hope I get the Pi-cromite running on my Raspberry and will try your code! Frank |
| zeitfest Guru Joined: 31/07/2019 Location: AustraliaPosts: 699 |
Just looked at the background of this ... amazing to see massive ephemerides etc crunchwork concisely condensed to fit to a picMX and basic ... .I am wondering, roughly what year does the epoch used range to ? |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
i feel its great but i understand nothing. Bahnhof Kofferklauen ? Plasma |
This is a quick coordinate Converter and a bit of intro I found useful (I confess, to get more into astronomy I bought a mirror making kit a long time ago...and it is still in the carton.. )Edited 2020-01-29 07:15 by zeitfest |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6571 |
And I have a 10 inch mirror gathering dust in the shed. Last time I looked at it, it was a sad sight. Jim VK7JH MMedit |
| retepsnikrep Senior Member Joined: 31/12/2007 Location: United KingdomPosts: 134 |
I agree brilliantly done but beyond normal mortals comprehension. Does this give accurate enough results to get a probe to one of the planets?? Or would we whizz by a few miles off course? Gen1 Honda Insights. |
Don't think I trust single precision on a micromite enough to find out however the idea of taking great strides with tiny compute does appeal. I followed a couple of threads a few years back about autonomous boats (like model size) crossing the Atlantic to win a prize - don't think it has been collected yet but it is great to see these little micro-controllers with GPS and satellite trackers drifting off hundreds of miles all on their own - actually navigating with sails... tacking and everything.h Edited 2020-01-29 19:55 by CaptainBoing |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3853 |
Microtransit "The ninth transatlantic race was open during 2018 and early 2019. Four boats competed from: Sailbuoy, Epsom College, Dalhousie University and Gortobot. It saw the first successful completition of the competition by SB Met." My wife and I followed with interest, since her son was in engineering at Dalhousie. Sadly, that one didn't make it. I had earlier followed Snoopy's efforts, as linked from the picaxe forum. ~ Edited 2020-01-30 00:37 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
yay! genuinely happy about that. ![]() I think it was snoopy that got me into it - I think the "processor" was changed to a micromite from a picaxe and the posts here were really interesting. It is a major feat as unpowered boats of that size will really feel the wind and tides. It amazes me what people can do... even the "failures" are amazing - days at sea navigitaing and having to tac into the prevailing westerleys. Neither crossing is easy but the east-west attempt has got the odds stacked against it from the start. Sadly the Microtransat challenge seems to have petered out (the registration page for 2019 is still open)... maybe contestants had the wind taken out of their sails by it having been won. I really appreciate the update coz I was interested but it sort of dropped of my radar. There was a similar thread about balloons doing a similar thing with LoRA modules for comms. Edited 2020-01-30 15:36 by CaptainBoing |
Voyager was the way to go... I am still amazed, such exactitude that a remote spacecraft path can be set up to skim past Pluto for photos, or settle into precise orbit around Saturn, by using careful math. |
