Forum Index : Microcontroller and PC projects : Pi-Cromite 1B PCB...
| Page 1 of 4 |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10109 |
Hello folks. ![]() I had a spare second, so whipped up version two(1B) of a Pi-cromite PCB. The alpha board was developed with led-bloon over in the PCB MANUFACTURING forum a month or so ago. Some changes were made to that alpha layout, and this is what we have now: ![]() ![]() This board accepts a Pi-Zero or Pi-Zero-W, and allows you to easily connect either an SPI LCD or an SSD1963-based LCD. Fully supports touch and all other PiCromite features. Pins on the LCD's etc are labelled, so you can easily ID a pin on the LCD header you are NOT using. ![]() The board is designed to accept an SPI LCD module on the top, or you can plug into the 40-pin header on any supported SSD1963 LCD module. A couple of self-adhesive rubber feet as spacers would be required for 1963 LCD's, or a short IDE HDD lead could also be used to link the board to the LCD module. I have ordered 10 boards for now, but if there is any interest here, please respond to this thread so I can try to gauge demand. If there is interest, I would be happy to release a constructor's pack(ZIP) with all the Gerber files, drill-data, BOM etc, then people could make as many as they want themselves. Smoke makes things work. When the smoke gets out, it stops! |
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 273 |
I am interested in a circuit board. Thanks for your effort Grog. |
| RonnS Senior Member Joined: 16/07/2015 Location: GermanyPosts: 123 |
i need two of them .. thank you |
jman![]() Guru Joined: 12/06/2011 Location: New ZealandPosts: 711 |
I will take a couple Jman |
| f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155 |
Hi Graeme, 2 PCBs also for me F1FCO, Pierre, south of France 73s de F1FCO |
| flip Senior Member Joined: 18/07/2016 Location: AustraliaPosts: 137 |
Hi Grogs, Put me down for 2 too thanks Phil |
| Bill7300 Senior Member Joined: 05/08/2014 Location: AustraliaPosts: 161 |
Two here Grogs. Bill Bill |
Hell - all gone. ![]() I will order some more, for anyone else wanting them. Would members prefer I sell them finished boards, or would they prefer that I upload a constructors pack with the Gerber's etc so they can make their own? Price per board would be US$3 at this stage. Postage(airmail) would be US$2 - up to four PCB's can fit in one envelope. Smoke makes things work. When the smoke gets out, it stops! |
| astroboy Regular Member Joined: 28/12/2014 Location: AustraliaPosts: 41 |
Hi Grogs I'd like two please. Would you be able to give details of "finished boards" please. John |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2984 |
Hi Grogs, Why Not.. I have Pi-Zero-W I am yet to fling into anything.. Scribble me up for 2. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
I'd like two as well please Grogs - prefer finished board. Greg |
What details would you like? Dimensions diagram or something? Board size is 93mm x 51mm if that helps. Smoke makes things work. When the smoke gets out, it stops! |
Oh very sorry. I don't know what "finished" means. John |
| atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 738 |
I'd like two as well please Grogs - prefer self soldering ;-) How many INCH has the Display??? Paypal, or what ??? Dietmar |
@ astroboy - Sorry for the confusion. I just mean finished boards - as in already manufactured and ready for you to solder. Finished/blank/ready to use. @ atmega8 - It is designed to match a 2.8" SPI LCD module. Or you can plug the parallel interface into any SSD1963 display, but you have to work out some form of support for the PiCromite PCB. The SPI LCD will mount directly to the PiCromite, and the mounting holes line up for this display. I have ordered another 20 boards to cover demand. It will be PayPal, yes. Smoke makes things work. When the smoke gets out, it stops! |
THX, please let us know, when you can ship them over the oceans...😄 |
| bigfix Senior Member Joined: 20/02/2014 Location: AustriaPosts: 132 |
Grogs, I go for three PCBs Guenter |
| Rosscovey Newbie Joined: 20/11/2014 Location: New ZealandPosts: 2 |
Hi Could you please put me down for two. thanks Ross |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1186 |
Hi Grogs, I would be very interested in two PCB's... THANKS A LOT! Frank |
| centrex Guru Joined: 13/11/2011 Location: AustraliaPosts: 320 |
Hi Yes please one for me also. Cliff Cliff |
| Page 1 of 4 |
