JAQForum Ver 26.09
   Page 46 of 52
Posted: 12:22pm
09 Aug 2023
mab1
  soudirector said
  Ziki_the said  Look like ATX choke.
Maybe 5pcs stocked and some thing like 15-17turns with multply coper wire, litz..
My sugestion..
this inductor is for mppt not ATX choke
You need to know what its inductance is in uH and, more importantly, what is its saturation current? Hard to tell from the picture, but it looks too small to handle 45A.
If course if the saturation current is lower you could limit the mppt to match the inductor, but you still need to know what it is.
Posted: 07:09pm
31 Aug 2023
soudirector
Can someone please educate me on who to calibrate this mppt because i am stuck there. I need a step by step on how to accomplish that.
I have already the build the brainbox and power board. i don't want my money and effort to be a waste.
Posted: 10:06am
01 Sep 2023
This might help,
https://www.thebackshed.com/forum/ViewTopic.php?TID=15935&P=2
Edited 2023-09-01 20:08 by Revlac
Posted: 02:43am
02 Sep 2023
soudirector
  Revlac said  This might help,
thanks Revlac, i appreciate. i am now getting the scope on to calibrate. The only things i need to calibrate are the Vin, Vout, Iin and Iout. the rest should leave at default?
Edited 2023-09-02 12:44 by soudirector
Posted: 08:03pm
11 Sep 2023
mab1
I think i may have discovered a possible 'bug' in MPPTv5_BV_tempco_day_totals ?
At the very end of Void init_controller there's this bit of code:
if (nvd.pwm_freq != 20 && nvd.pwm_freq != 40)
   // set default at 20 kHz
   timer1_period = 833;
   baud_waits = 1;
   ints_second = 19200;
   freq_scale = 1;
 else
   timer1_period = nvd.timer1_period;
   baud_waits = nvd.baud_waits;
   ints_second = nvd.ints_second;
   freq_scale = 2;
If my reading is correct(?!), then if nvd.pwm_freq == 20 it will actually set freq_scale = 2 instead of 1
I dug this up as i seemed to be getting radically longer delays at 20kHz than at 40kHz, and noticed freq_scale = 2:
void dlay(int n)
 int d;
 if (freq_scale == 2)
   d = n * 8;
 else
   d = n;
 dlay_timer = 0;         // a simple delay loop that uses the 20kHz pwm interrupt as a clock
 while(dlay_timer < d) ; // This while loop will only exit if pwm interrupt is working.
Trouble is,i've hacked my version of the code so much i'm not sure what i've messed up, but that appears to be in the original code.
I'm still not sure how i did this to the day 4 total
Posted: 03:12am
12 Sep 2023
poida
Hi Mab1
you have found a bug. This is good, I can fix it for us.
Thanks for that.
we need to apply the correct frequency scale factor
which is used in a few places in the code.
The fix is in Red
  baud_waits = 1;
  freq_scale = 1;
else
  if ((nvd.pwm_freq == 20)
     freq_scale = 1;
  else
     freq_scale = 2;
the next bit also seems an error and likely a remnant of testing something or other.
void dlay(int n)
int d;
  d = n * 8;
else
  d = n;
change this to
void dlay(int n)
 int d;
 d = n * freq_scale;
 dlay_timer = 0;         // a simple delay loop that uses the 20kHz (or 40 kHz) pwm interrupt as a clock
here is the updated code
mpptv5_BV_tempco_day_totals.zip
Posted: 11:03am
14 Sep 2023
Ziki_the
Today I played with fire, the result is extremely unusual. The original choke(epcos) was 1.4mH from the motor inverter 11KW.
An iron torus cut in half.
I will try to wound some wire and give a litle test.
Did someone stumped on something lile this?
Posted: 10:00am
16 Sep 2023
andymc70
Hello All
Just had another 2 IRBF4110 fail on my MPPT's, i just notice they are only rated to 100V VDSS, i just wondering if i can replace them with irbf4115, these are rated to 150v VDSS. But the gate voltage is only at 5V, whereas the 4110 is at 20.
I am unsure of the gate voltage required or if 5V is not enough.
Its also weird that the 2 IRBF's where on different MPPT's connected to the same battery.
Andy
Edited 2023-09-16 22:01 by andymc70
Posted: 12:15pm
16 Sep 2023
Ziki_the
@andy
Yes you can use irbf4115, gate voltage for them is -+20V.
This mppt give out to gate 12V max.
For dead mosfets, only one per board died?
All best.
Edited 2023-09-16 22:17 by Ziki_the
Posted: 01:21pm
22 Sep 2023
Tribal Tronix
Just did a speed read on this thread. Wow is all i could say. Please which code has the i2c on the main board. I would prefer only one controller...
Posted: 11:29am
17 Oct 2023
nickskethisniks
Anyone made a higher voltage version?
I'm looking for some mosfets/diode suggestions.
Peter, do you think the code would work for a mppt controller but with boost topology?
(Apart from the high dutycycles that could be problematic with boost.)
Posted: 05:09am
18 Oct 2023
poida
NO idea at all if it will work in a boost situation.
We can always try though. I think you could knock out a prototype
that uses the brainboard 10 pin control and we see what happens.
I would need to alter the code so that Vout is expected to be larger than
Vin, etc..
Posted: 06:52pm
18 Oct 2023
flyingfishfinger
  poida said  NO idea at all if it will work in a boost situation.
It will not, with the existing hardware - a boost converter has a different circuit from a buck converter.
Buck:
Boost:
So the arrangement of the inductor vs the MOSFETS is different as is the control algorithm as already indicated..
R
Posted: 12:44pm
19 Oct 2023
nickskethisniks
The software should work with some minor changes, no problem. Buck or boost will work the same, increase dutycycle for more energy flow until mppt is reached.
The hardware, yes a little bit different, but not much, I have a simple protoboard that works with simple voltage tracking firmware, but I still need to add 2 current sensors to work with Peter his code. My code has stability issues when running the loop too fast, 1ms works ok.
Posted: 03:43pm
19 Oct 2023
mab1
I'm not sure what your definition of higher voltage is; mine runs at a about 5:1 voltage ratio on a 24v system.
https://www.thebackshed.com/forum/ViewTopic_mobile.php?FID=4&TID=15938
For the mosfets i used one that was recommended by pd-- : irf200p222 - 200V - not cheap and i suspect I'm massively underrunning them as they are rated to 182A continuous. The schottkys are apt30s20bctg, 200V again.
As for boost - I'm probably speaking beyond my knowledge here,  but i think you have to determine the maximun allowable pwm  duty cycle % (obviously you can't run 100%), which would probably depend on in:out voltage ratio,  and you might have to monitor input amps during a mppt scan, but it ought be doable.
Edited 2023-10-20 01:48 by mab1
Posted: 11:01pm
19 Oct 2023
poida
How the code works:
It requires one simple fact to be true, that is
output voltage is proportional to duty cycle width.
And that it is monotonic such that it is always
proportional to PWM width from zero to max width.
Once that is sorted, and it IS since it's a buck converter
the code periodically does a search from the smallest PWM width
to the max width IF NEEDED, looking for the maximum output power
that is going into the battery.
(I frankly could not give a rat's what the solar array power is doing
all I want is to get max power INTO the battery. max power OUT OF
the array is of zero interest. we are charging a battery here..)
The PWM width that give max. power into the battery is noted and the scan has
completed. For the remainder of the 60 seconds a slow closed loop control ("tracking") is run, keeping output at this PWM width but also
limiting output current if needed due to battery voltage arriving at
the absorb or float settings or the user's max. current being exceeded.
To control the output all I need do is reduce or increase the PWM width.
The scan can be stopped early should there be an excess of power available
and the battery voltage is exceeded or the max output current setting is exceeded.
Either of these will set the PWM run max value for the remainder of the 60 seconds.
Boost converters also have the same monotonic proportional relation
of output voltage verses PWM width.
I think my code will run fine, apart from some minor changes to
stop condition testing. It now tests if battery voltage is greater than array voltage and stops the converter. Obviously this would be useless in a boost design.
But the mppt scan code will not need any change.
Nor the tracking code (which runs for about 57 seconds after the mppt scan)
Just some of the run time test conditions.
Posted: 10:02pm
16 Nov 2023
flyingfishfinger
So I just came back from visiting our offgrid site after 4 months absence. The controller is running fine, but I do need some help with the software due to some pretty strange behaviour.
I mentioned before that the "night" current is sometimes negative, near zero due to slight sensor drift. I also mentioned I didn't have any luck clamping it to zero myself.
There also is not much light during the winter months (coming up), so I guess it spends quite a bit of time in night mode these days.
As a result, I had accumulated NEGATIVE 72 kWh of charge and the current sensors were reporting NEGATIVE 1A in night mode (??). I obviously recalibrated the device when I was there, but this is kind of a majorly annoying bug.
The temperature at my site fluctuates from +40C in high summer to just under freezing in the winter but not that much during the day. From the datasheet of the ACS758LCB-050U, the error is about 10mV from 0C to 25C and the sensitivity is 60mV / A. So I might get 0.2A drift over temperature (about what I do see).
At 100V input, that's a 20W difference and over 120 days, if my math is right, that is approximately 56kWh of error, not too far from what I saw (!). If my batteries spend most of their time in float when I'm not there, I would be mostly accumulating error instead of real charge.
Do we have some thoughts about improving / fixing the behaviour?
Edited 2023-11-17 08:04 by flyingfishfinger
Posted: 10:24pm
16 Nov 2023
poida
I suspect the mppt is not draining energy from the battery in this situation.
so there is that.
But I agree this behavior is disappointing.
Thanks for working out a potential cause for it.
The current sensors have large offsets and offset tempco as you have shown.
These error sources will be present during the daytime as well as at night.
So they will effect both NIGHT mode and the daytime MPPT and ABSORB modes.
maybe you and I could work out some sort of plan to deal with the offset errors.
(sensor gain seems to be stable, thankfully)
my first idea:
whenever a sensor reports negative current, this will trigger a recalibration of the zero point. Maybe only do this once an hour. We do this in all operating modes.
what could go wrong with this?
there could be more time spent in MPPT but under very low power.
this is not a problem. probably a good thing.
During daytime with proper solar power, the recal will not run since current
values will be positive and a lot higher than the offset drift.
how I would code it:
monitor both current sensors, checking once a minute.
if after 60 minutes of a sensor having a negative value, the recal code will
be run and the 60 minute timer is reset to zero.
It will be important that we prove that there is zero current flowing through
the sensors at these times we recalibrate.
what do you think FF?
Posted: 11:10pm
16 Nov 2023
flyingfishfinger
  poida said  I suspect the mppt is not draining energy from the battery in this situation.
so there is that.
It is not, I verified that - at least on the input side. Is the capacity calculated from the input or output, on that note?
Your suggestion seems reasonable. What do you mean by "could spend more time in MPPT under low power" ? The trigger for night mode is still some small number of positive W - except that if the current is negative, that will be negative as well.
I am planning to head back up on Dec 1 - 3rd, and after that probably not until spring. Do you think we can work something out before then that I can try out?
No big deal if not, as long as having a negative current will still charge the battery (does the MPPT scanning check for "least negative" in addition to "most positive" power correctly?)
I'm using the I2C version, if that changes anything (on that note, I've run it up to about 1500W and found no I2C / display issues)
R
Posted: 11:29pm
16 Nov 2023
poida
important that I know you are using the i2c version - I don't want to
work on the wrong one for you.
the mppt search looks for the greatest output power, when scanning
the PWM width range from very low to max width.
This search is only done when in MPPT mode or NIGHT mode
The search records the max output power and once found will set
the tracking code to only go up to the PWM that produced that max power.
I will try to do this over the weekend and test it.
   Page 46 of 52
