Local Time 07:27 16 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.05.05 beta
     Page 4 of 7
Sasquatch
Posted: 10:19pm 18 Aug 2020
  matherp said
  Quote  I am noticing some issues with 5.05.05b11
Oops - sorry: I was playing with an idea that didn't work and didn't back it out properly. Please download again - should be OK now
Yep, that seems to have the sprite issue fixed.
Thanks again for all your hard work on this project!!!
-Carl
MauroXavier
Posted: 10:42pm 18 Aug 2020
  Sasquatch said  It's actually fun to play fast, and the slowdown when the screen is filled with "bad guys" isn't nearly as noticeable.  The music also speeds up???  I guess needing to regulate the speed is a nice "problem" to have
The speed would not be a problem because all routines are timed to cap the framerate and the sound are fixed to 10ms using a native interrupt. I will see now what´s going on...
MauroXavier
Posted: 11:14pm 18 Aug 2020
Well, I have tested here. I have the Y version of the CPU that is running at 400Mhz, I don´t saw any difference in the speed of Gauntlet in this firmware.
Sasquatch
Posted: 12:08am 19 Aug 2020
  MauroXavier said  Well, I have tested here. I have the Y version of the CPU that is running at 400Mhz, I don´t saw any difference in the speed of Gauntlet in this firmware.
So it looks like I have only played Gauntlet with Option RAM enabled.  When I upgraded, Option RAM was off.  With option RAM enabled, the game slows down much more with additional monsters on screen.  So I guess I was always playing it slower than normal and now I have "normal" speed without Option RAM?  This may be why it seemed so much faster after the firmware upgrade.
With Option RAM off, I get ~20FPS maximum and ~10FPS with 40 monsters on screen.  At least that's what the numbers in the lower right of the screen seem to be telling me.  At 10FPS the game is noticeably slower but still seems smooth and responsive.  I'll do some more testing to see what I get with Option RAM back on.
Edited 2020-08-19 10:13 by Sasquatch
-Carl
MauroXavier
Posted: 12:39am 19 Aug 2020
Humm... I´m not using OPTION RAM for a while, I will test it too.
This week I intend to launch a new video on YouTube and update the source to support 2 players. In my tests, the speed was almost the same as one player (what consumes more CPU is the enemies and 8-bit music style).
Thanks for your tests!
Sasquatch
Posted: 12:58am 19 Aug 2020
Yes!  When the game slows below 10FPS it has more noticeable lag and becomes much less smooth moving and scrolling.  With Option RAM enabled I am seeing frame rates as low as 5-6 when the screen is full of monsters.  The Troll looking monsters seem even worse than the Ghosts.
-Carl
mkopack73
Posted: 03:52pm 19 Aug 2020
matherp,
Is there any way we can get maybe 2 additional digits of precision in the firmware version number to indicate the beta/release build revision?
ie: you post up build 5.05.05b10, but MM.INFO will report that back as 5.0505 currently... Could we get it to report that in some way to indicate the beta number as well? (I was initially thinking 5.050510 but that won't work because it'll have a rev > than the 5.0505 that the actual release will get... :( ) I guess this is why MS and others use whole number build versions and even the betas get a full number and then final release gets a higher number...
I'm just looking for a way to allow us to be able to catch when we need the firmware to be above a specific beta build number (like we used something that you fixed in 5.05.05b6 for example)....
Otherwise I guess we really can only use that check for actual firmware release version checks...
Posted: 05:46pm 19 Aug 2020
  Quote  Is there any way we can get maybe 2 additional digits of precision in the firmware version number to indicate the beta/release build revision?
I think (hope) this is a temporary issue. I expect to release 5.05.05 in the next couple of weeks unless many more bugs arise. In any case 5.05.05 will essentially just be a bug fix release and the code should then be pretty stable. Certainly I'm not intending to make any further functional changes in the near future
Posted: 07:19am 20 Aug 2020
5.05.05b12 posted
Thanks to Geoff for providing a final fix to the DATA issue. The code now correctly interprets unquoted strings in both upper and lower case and also allows expressions in both upper and lower case. This means all existing programs using expressions in DATA statements should now work again.
New MODE 7 320x240. This give a full screen display with square pixels on a normal aspect ratio monitor. Pages 0-13 are available in this mode with pages 0 and 1 in fast processor memory
Experimental new OPTION for comment.
OPTION DEFAULT MODE n
n can be 800 (default) or 640
This sets the resolution in mode 1 to be either 800x600 or 640x480. This should allow the CMM2 to use the cheap 7" TFT screens like this.
This is a permanently saved option but does not cause a reboot so can be used in a program. However, developers should probably not use it in code to be circulated as you will reconfigure a user's CMM2
vegipete
Posted: 07:44am 20 Aug 2020
It seems dangerous to me if mode 1 can have different resolutions. It might be safer to have, say, a mode 8 that is 640x480 and allow the default mode to be 1 or 8
The data saga.
If I want a string that is the same as a keyword, variable or expression, I must put in quotes.
If I want a comma to be part of a string, the string must be in quotes.
What happens if an unquoted string in a data statement is later used as a variable name?
CONST col_dark = &h101010
data col_dark, col_light, red
col_light = &hA0A0A0
What will the data values be? 1, 2 or 3 numbers? (Does "red" only have a particular value when used in the rgb() statement?
realmnm
Posted: 07:50am 20 Aug 2020
Awesome!
If in my program I set mode 1 and the user has set it to 640, I will be in a 640x 480 screen, correct?
Martin
This signature intentionally left blank.
Posted: 09:07am 20 Aug 2020
  Quote  If in my program I set mode 1 and the user has set it to 640, I will be in a 640x 480 screen, correct?
Correct and you can tell by reading MM.HRES
Posted: 10:57am 20 Aug 2020
  Quote  It might be safer to have, say, a mode 8 that is 640x480 and allow the default mode to be 1 or 8
Thinking about it more, this is a better idea. It is a bigger job but I'll make the change and re-post
MauroXavier
Posted: 11:25am 20 Aug 2020
  matherp said  New MODE 7 320x240. This give a full screen display with square pixels on a normal aspect ratio monitor. Pages 0-13 are available in this mode with pages 0 and 1 in fast processor memory
Final Fight and Gauntlet will appreciate this new resolution.
Thanks!
capsikin
Posted: 12:08pm 20 Aug 2020
Another option would be a mode 8 that's 640x480, and a mode 0 (or other new number) that's either 640x480 or 800x600 (and is the default), leaving mode 1 as 800x600
Edited 2020-08-20 22:09 by capsikin
Geoffg
Posted: 12:18pm 20 Aug 2020
  vegipete said  What happens if an unquoted string in a data statement is later used as a variable name?
It will stay the same (ie, a string).  This is because the READ command uses the type of the variable being used in the command to determine how to treat the DATA element that it finds.
So, for example, in the latest beta:
  DIM tt = 123
  DATA tt, tt
  READ n, s$
Will result in n having the value 123 and s$ having the value "tt".
As a rule, all strings in DATA statements should be quoted.  Unquoted strings can get messy and they are only allowed in MMBasic because Microsoft BASIC allowed them.  I am not sure why Bill did this but we are now stuck with it.
BTW, the reason why you must quote strings that are the same as function names is that these are turned into single byte tokens when the program is loaded into program memory and the tokeniser does not have the smarts to know that the unquoted string is part of a DATA statement.
  vegipete said  Does "red" only have a particular value when used in the rgb() statement?
Yes, the RGB() function looks for specific text (ie, red, blue, etc) and returns that colour if it finds that text.
Geoff
Posted: 08:48pm 21 Aug 2020
Hi Peter,
Could this be made to work? or is there an alternative way to choose a DATA section to restore based on a value held in a variable without using IF or SELECT CASE:
Cls
Read s$
Print s$ ' Prints "foo".
label$ = "foo_label"
Execute "Restore " + label$
Read s$
Print s$ ' I would like this to Print "foo" too.
foo_label:
Data "foo"
bar_label:
Data "bar"
Currently reports:
[7] Error: Unknown command
Posted: 09:44pm 21 Aug 2020
  Quote  Could this be made to work?
No: as I have said many times before I do not and will not change Basic language elements
Posted: 09:51pm 21 Aug 2020
Sorry, is that what I asked for? I thought I was asking you to extend EXECUTE to allow it to be used to call RESTORE ... and EXECUTE isn't a Basic language element ... as in you added it specifically for the CMM2.
Edited 2020-08-22 07:52 by thwill
Posted: 09:55pm 21 Aug 2020
My mistake, didn't know restore had an optional parameter. Does it work at all?
     Page 4 of 7
© JAQ Software 2025
