Local Time 12:57 03 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Alpha Firmware
     Page 14 of 17
Posted: 06:53am 11 Jun 2021
I use that tiny little RTC module in most of my projects, and always seems to work fine.
Posted: 07:31am 11 Jun 2021
While Peter is having his well deserved rest, playing with the picomite surfaced some things to desired. Maybe this is not the right time, but here is what I desire for my area of interest.
#1: in the editor, a larger buffer size (F4/F5 can only copy some 255 characters). Maybe it is possible to enlarge that to 1k ?
#2: a "DAQ" command that autonomously captures ADC data with accurate sample rate. I have tried to write such (see my posts about calculating RMS on the MX170) in basic, but fail to get sufficient speed and timing accurate. General requirements:
a/ programable sample frequency up to 4kHz
b/ minimal 2 ADC's (i.e. measure voltage and current).
c/ strict phase (or-time) relation between the 2 ADC's. Sampling simultaneous is best, but if there is X us between them that is also fine. Math can solve that, and for some applications that is not even critical.
d/ put the raw ADC data into an integer array X(1,n) where n is the number of samples.
nice to have:
e/ optional external trigger (i.e GP1).
f/ optional running in background
#3: Nice to have: can be simple, but can also get as large as you want it. It would be nice to have a "GRAPH" command that can display a set of data in a window on the display. In it's simplest form it scales a single dimension array to the windows size and plots the datapoints using linear interpolation. Things that can be added are line color, axis, ticks, legend, X-Y graph, other graphing forms (histogram), 3d graph. Again, this is nice to have, because it can be done in a page of basic code, and is not time critical. And work arounds (like copying a CSV to excel) exist. Maybe more for CMM2 than pico.
Posted: 08:02am 11 Jun 2021
I agree on point #1, Volhout. 255 chars can be pretty annoying at times and a bigger buffer would add to the usability of the editor immensely. However, I suspect that it might be using the string handling routines of MMBasic (I think it's the same on the other platforms). In that case we might be stuck with it.
Posted: 09:05am 11 Jun 2021
  Mixtel90 said  I agree on point #1, Volhout. 255 chars can be pretty annoying at times and a bigger buffer would add to the usability of the editor immensely. However, I suspect that it might be using the string handling routines of MMBasic (I think it's the same on the other platforms). In that case we might be stuck with it.
CMM2 has a larger buffer, so unless CMM2 has a special patch, it should be possible.
Posted: 09:27am 11 Jun 2021
CMM2 edits directly to the ASCII file on the SD card though. There's no user program in RAM during editing so all the resources are available too.
Posted: 12:16pm 11 Jun 2021
@Peter: there is something wrong with MATH FFT
Yesterday I tested MATH FFT MAGNITUDE on the pico using a 1024 size array, and reported the output was a spectrum. I however did not fully trust the result, as there where spurious peaks in the spectrum I could not explain.
Last night (yes, deep in the night) I tried to reproduce on the CMM2. But the CMM2 gave similar results. I was not sure if it was me, who did not understand FFT, or something wrong with both implementations.
I noticed the peaks in the spectrum could be reduced by applying windowing on the input signal, so I experimented with windowing on both pico and CMM2, and bot behaved the same, but different from what I would expect.
Here is a picture of the pico result of a windowed (sin^2 window) sine wave and the resulting spectrum.
However, if I input the data in excel, and use the analysis toolpack (contains fft) on the same dataset, the result is different, and in line with what I would expect.
This is a difference I cannot explain. The excel magnitude graph is clean, no spurious. At least not in this linear magnitude view.
The only thing I can think of that could explain a bit is that the MMBasic magitude  plot is in some kind of logaritmic scale. But even then, the enormous peak at the right side should be visible in the linear view in excel.
Note that both plots show 0-511 values of the 0-1023 fft array.
Below the test program I used for this test. It is not nice formatted because I was constantly trying to find the bugs in it, and add debug routines.
'GFXterm - magnitude FFT
'init gfxterm parameters
Const GFX=Chr$(16)
Const ENQ=Chr$(5)
Const ACK=Chr$(6)
Print GFX "?"
Input Gw, Gh
Print GFX "clear" 0, 0, Gw, Gh
GoSub drw
'defines
n=1023   'samples for fft (multiple of 2 - 1)
cy = 10  'cycles of sinewave in n samples
Dim a!(n),fm!(n),fp!(n)
GoSub sinfill
'GoSub sqrfill
window=3      '1=trapezoid, 2=triangle, 3=sin^2
GoSub window  'if required
'GoSub sinlist
'End
GoSub sinshow
Math fft magnitude a!(),fm!()
'GoSub magnitudelog
'Math fft phase a!(),fp!()
GoSub fftshow
'GoSub phshow
End
'window the input signal to remove spurious
window:
 If window=1 Then
   For i=0 To n/cy
     a!(i)=a!(i)*i/(n/cy)
     a!(n-i)=a!(n-i)*i/(n/cy)
   Next i
 ElseIf window =2 Then
   For i=0 To n/2
     a!(i)=a!(i)*i/(n/2)
     a!(n-i)=a!(n-i)*i/(n/2)
   Next i
 ElseIf window=3 Then
   For i=1 To n
     a!(i)=a!(i)*Sin(Pi*i/n)*Sin(Pi*i/n)
   Next i
 EndIf
Return
'show magnitude fft on graphics terminal
fftshow:
 Print GFX "ink" 255, 255, 0, 2
 'scan magnitude array
 mi!=0:ma!=0
 'note: the fft array is symetrical, you only need look at first half
 For i=0 To n/2
   mi!=Min(mi!,fm!(i))
   ma!=Max(ma!,fm!(i))
 Next i
 'Print mi!, Ma!
 ygain=-Gh/(2.2*(ma!-mi!))
 yoffset=Gh-ygain*mi!
 xgain=2*Gw/(n+1)
 xoffset=0
 For i=0 To n/2-1
   x1=i*xgain+xoffset
   x2=(i+1)*xgain+xoffset
   y1=fm!(i)*ygain+yoffset
   y2=fm!(i+1)*ygain+yoffset
   Print GFX "line" x1,y1,x2,y2
 Next i
Return
magnitudelog:
 Print "magintude log"
 For i=0 To n
   fm!(i)=20*Log(fm!(i))/Log(10)
 Next i
Return
'show the phase of the signal
phshow:
 Print GFX "ink" 0, 0, 255, 1
 'scan phase array
 mi!=0:ma!=0
 For i=0 To n/2
   mi!=Min(mi!,fp!(i))
   ma!=Max(ma!,fp!(i))
 Next i
 'Print mi!,ma!
 yoffset=3*Gh/4
 xgain=2*Gw/(n+1)
 xoffset=0
 For i=0 To n/2-1
   x1=i*xgain+xoffset
   y1=fp!(i)*ygain+yoffset
   y2=fp!(i+1)*ygain+yoffset
 Next i
Return
'fill input array a() with sine wave samples
sinfill:
For i=0 To n
 a!(i)=Sin(i*2*Pi*cy/n)
'  a!(i)=a!(i)/2+0.5 'offset
'  Print a!(i),
Next i
Return
'fill input array a() with square wave samples
sqrfill:
period=Int((n+1)/cy)
For i=0 To cy-1
 For j=0 To period/2 - 1
   a!(i*period+j)=1
 Next j
 For j=period/2 To period
   a!(i*period+j)=-1
 Next j
'  Print a!(i),
Next i
Return
'show the graph of the input signal
sinshow:
 Print GFX "ink" 0, 255, 0, 2
 ygain=-Gh/5
 yoffset=Gh/4
 xgain=Gw/(n+1)
 xoffset=0
 For i=0 To n-1
   x1=i*xgain+xoffset
   y1=a!(i)*ygain+yoffset
   y2=a!(i+1)*ygain+yoffset
 Next i
Return
sinlist:
 For i=1 To n
   Print a!(i)
 Next i
Return
'draw frames
drw:
 Print GFX "ink" 255, 255, 255, 2
 Print GFX "line" 0,Gh,0,Gh/2+1
 Print GFX "line" 0,Gh,Gw,Gh
 Print GFX "line" 0,Gh/2+1,Gw,Gh/2+1
 Print GFX "line" Gw,Gh,Gw,Gh/2+1
 Print GFX "line" 0,0,0,Gh/2-1
 Print GFX "line" 0,0,Gw,0
 Print GFX "line" 0,Gh/2-1,Gw,Gh/2-1
 Print GFX "line" Gw,0,Gw,Gh/2-1
Return
Posted: 01:06pm 11 Jun 2021
Is the basic FFT correct?
Posted: 01:36pm 11 Jun 2021
  matherp said  Is the basic FFT correct?
I just tried running the normal FFT and calculate the magnitude samples from:
Magn = sqr(Re^2+Im^2) and get the exact same result. Something fishy in the fft function. But it is the same in the CMM2. If you solve it there, you solve it in pico...
Could it be something with the format of the float used ? But if I look at your earlier post for the H7 the FFT graph (magnitude) did not show the high peak at the right of the spectrum (and you also plotted 512 values from the 1024 array). Could it be something that was changed with the H7 -> CMM2 transition. And now pico inherits...
Edited 2021-06-11 23:40 by Volhout
Posted: 02:09pm 11 Jun 2021
Do you have an H7 to test with, or can anyone else volunteer? Both with the older firmware and the 5.07 beta.
Posted: 04:58pm 11 Jun 2021
Peter,
I do not have an H7, someone else might be able to double check.
This is the CMM2 progam I use to check FFT
pressing "a" increases the number of sine waves per 1024 fft samples
pressing "z" decreases
pressing "w" cycles through some windows (none, triangular, (co)sine (=hann))
'check fft magnitude function
n=1023 'samples
cy=10  'cycles
dim a!(n),fm!(n)
w=0  'window type, 0=none
do
 cls
 'draw 2 frames using mm.hres mm.vres
 box 50,0,(mm.hres-51),mm.vres/2-2
 box 50,mm.vres/2,mm.hres-51,mm.vres-1
 'prepare input signal
 sinfill
 if k$="w" then w=(w+1) mod 4
 if w then window
 'plot input signal
 plot_in
 'do fft
 math fft magnitude a!(),fm!()
 'plot fft
 plot_fft
 'keyboard commands
 do
   k$=inkey$
 loop until k$<>""
 if k$="a" then cy=cy+1
 if k$="z" then cy=cy-1:cy=max(cy,2)
loop until k$="q"
end
'subroutines
'fill the input array a!() with cy cycles of sinewave
sub sinfill
 for i=0 to n
   a!(i)=sin(2*pi*cy*i/n)
 next i
end sub
'apply a window over the input signal (triangle for now)
sub window
 if w=1 then
   for i=0 to n/2  'linear
     a!(i)=(i/n)*a!(i)
     a!(n-i)=(i/n)*a!(n-i)
   next i
   ? @(60,5) "window linear"
 else if w=2 then
   for i=0 to n    'quadratic (do linear twice)
     a!(i)=(i/n)*a!(i)
   next i
   ? @(60,5) "window quadratic"
 else if w=3 then
   for i=0 to n    'cosine window
     a!(i)=(1-cos(2*pi*i/n))*a!(i)
   next i
   ? @(60,5) "window cosine"
 end if
end sub
'plot the input signal in the upper window
sub plot_in
 'find minimum and maximum
 mi!=0:ma!=0
 for i=0 to n
   mi!=min(mi!,a!(i))
   ma!=max(ma!,a!(i))
 next i
 '? mi!,ma!
 'calculate gain and offset to fit it into the window
 xgain=(mm.hres-50)/n
 xoffs=50
 ygain=-(mm.vres/2.3)/(ma!-mi!)
 yoffs=mm.vres/4-ygain*(ma!+mi!)/2
 'plot the actual samples  using linear interpolation
 for i=0 to n-1
   line i*xgain+xoffs,a!(i)*ygain+yoffs,(i+1)*xgain+xoffs,a!(i+1)*ygain+yoffs
 next i
 'add legend
 ? @(mm.hres/2,5) "input linear"
 ? @(5,5) str$(ma!,2,2)
 ? @(5,mm.vres/2-20) str$(mi!,2,2)
end sub
'plot the fft output in the lower window
sub plot_fft
 'find min and max and where max is
 mi!=0:ma!=0
 for i=0 to n/2  'fft output is symetrical
   mi!=min(mi!,fm!(i))
   ma!=max(ma!,fm!(i))
   if ma!=fm!(i) then cf=i':? cf
 next i
 '? mi!,ma!
 'calculate scaling to fit the window
 xgain=2*(mm.hres-50)/n
 xoffs=50
 yoffs=mm.vres-20
 'plot the fft graph
 for i=0 to n/2-2
   line i*xgain+xoffs,fm!(i)*ygain+yoffs,(i+1)*xgain+xoffs,fm!(i+1)*ygain+yoffs
 next i
 'add legend
 ? @(mm.hres/2,mm.vres/2+15) "magintude linear"
 ? @(5,mm.vres/2+5) str$(ma!,2,2)
 ? @(5,mm.vres-30) str$(mi!,2,2);
 'put marker ticks in multiples of centre frequency
 for i=0 to n/2-2 step cf
   line i*xgain+xoffs,mm.vres/2,i*xgain+xoffs,mm.vres/2+5
   if ((i mod(5*cy)) = 0) then
     line i*xgain+xoffs,mm.vres/2,i*xgain+xoffs,mm.vres/2+15
   end if
 next i
end sub
panky
Posted: 12:15am 12 Jun 2021
I have full SD card access in a15 however, using a25 as follows gives an error
SD card connected to GP2,3,4 and 5
(works fine in a15 with these pins - I can list directory contents OK)
>OPTION RESET
>UPDATE FIRMWARE
- copy a25 to Pico - OK
- power cycle
>OPTION RESET
>OPTION SYSTEM SPI GP2,GP3,GP4
-all good, no error message
>OPTION SDCARD GP5
>FILES
Error : SD Card not found
also tried using GP1 as SD card CS but same error
Doug.
Posted: 12:26am 12 Jun 2021
Works for me, so there's nothing wrong in theory with your setup:
> option list
OPTION SDCARD GP5
> files
A:/
     1351  bench.bas
    26240  ccpico.bas
      201  circles.bas
     3164  gameoflife.bas
      618  gettime.bas
      636  grain.bas
    11008  gui.bas
       22  hello.bas
       35  hello0.bas
     1444  mcp23017.bas
      817  menu.bas
      364  pelican.bas
      309  settime.bas
      367  speed.bas
     4515  ta.bas
     4700  tain.txt
     3017  taout.txt
0 directories, 17 files
panky
Posted: 01:24am 12 Jun 2021
  lizby said  Works for me, so there's nothing wrong in theory with your setup:
Can't put my finger on what I am doing wrong, particularly as it works fine under a15 and other than updating the firmware to a25 (and doing the reset thing), everything else is the same.
Is there any way to read which alpha version is loaded? After the firmware upgrade, I have to close TerraTerm then reset the Pico and restart TerraTerm so I never see the sign-on banner.
D.
Edit: To explain the last para, everytime I reset or power cycle, I loose the USB connection thus I never auto reconnect like others have indicated happens for them. I am running Win7 pro on an Acer laptop and connect to the Pico direct from USB port (ie. no external hub). I have to close TerraTerm before the reset then restart after the reset/power cycle, and it then comes up online however, the startup banner has passed me by at this stage.
Edited 2021-06-12 11:30 by panky
panky
Posted: 01:35am 12 Jun 2021
Anyone else out there driving the Pico from a Win7 Pro machine?  If so, can you advise what driver you are using?
Doug
Posted: 01:39am 12 Jun 2021
https://www.raspberrypi.org/forums/viewtopic.php?f=146&t=300053
Worth a try.
led-bloon
Posted: 01:55am 12 Jun 2021
No troubles here with a25 and SDCard (with defaults too)
When all else fails, try flash_nuke.uf2 and start afresh.
Part of the pico-sdk and can post if you haven't got it
led
Miss you George
panky
Posted: 02:21am 12 Jun 2021
Loaded drivers as per Jim's suggestion above.
Reloaded a25 and sdcard is now working although I can
not see how that would fix the problem.
Note I had reloaded a25 numerous times before and
carried out identical configuration without any success
till now.
I still loose the USB connection on every reset or
power cycle so I still never see the sign on banner
but at least I have access to the sd card.
Thanks for the assist.
D.
Posted: 08:40am 12 Jun 2021
Have you tried messing with cpuspeed, Doug? It defaults to 125000 from a17, which *should* be fine for all Picos. It can go down to 48000 though.
You can see the alpha version in the banner on power-up or by doing a hardware reset by grounding the RUN pin.
Posted: 12:53pm 12 Jun 2021
I haven't yet found the magic for TEMPR to read a DS18B20. I think I have it wired right, with a pullup resistor, but with multiple pins attempted, I get like this:
?tempr(27)
Error : Invalid configuration
> setpin 27,din
> ?tempr(27)
Error : Pin 27 is in use
Same with DOUT. I know that the DS18B20 requires both input and output. How do I get a reading with the picomite? (User error is always a possibility.)
Posted: 12:58pm 12 Jun 2021
Sounds like I may have b....ed it. Try the version where I announced it was working.
You should not set the pin prior to using TEMPR
Edited 2021-06-12 23:00 by matherp
     Page 14 of 17
© JAQ Software 2025
