Forum Index : Microcontroller and PC projects : PicoMite Alpha Firmware
Page 13 of 17 | |||||
a24 PicomiteV5.07.00a24.zip UARTS now working COM0 with UART0TX/RX and COM1 with UART1TX/RX - minimal testing e.g connect pin 1 to pin 12, connect pin 2 to pin 11 setpin 11,uart1tx:setpin 12,uart1rx:open "com1:115200" as #1 setpin 1,uart0tx:setpin 2,uart0rx: open "com0:115200" as #2 print #1, "Hello world" print input$(100,2) print #2, "Bye world" print input$(100,1) close 1 close 2 Edited 2021-06-10 07:53 by matherp |
led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 204 |
FYI Not true, as there is Fuzix. Read about it, starting at: Fuzix Info Close to the bottom of the page. Amazing... led Miss you George |
Perhaps the closest there is to documentation for the picomite is the manual for the Armmite F4. But this is an alpha release, very much a work in progress, and many things in the F4 manual are not implemented, and some may never be. Other things, like the setting up of the pins for SPI, I2C, and Com ports and for an LCD (not yet implemented) are different, and are documented only in this thread and perhaps here. For the Micromite Summary page, start here. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Success with Tx looped back to Rx: > list Dim string cr=Chr$(13), lf=Chr$(10) a$="A wonderful bird is the pelican,"+cr+lf+"His bill will hold more than his b elly can,"+cr+lf b$="He can take in his beak"+cr+lf+"Enough food for a week"+cr+lf+"But I'm damn ed if I see how the helican!" SetPin 1,uart0tx:SetPin 2,uart0rx: Open "com0:115200" As #1 Print #1,a$;b$ Pause 100 Print Input$(255,#1) Close #1 > RUN A wonderful bird is the pelican, His bill will hold more than his belly can, He can take in his beak Enough food for a week But I'm damned if I see how the helican! But . . . > SetPin 1,uart0tx:SetPin 2,uart0rx: Open "com0:115200" As #1 > print #1,"ABC" > ?loc(#1) Error : Internal fault (sorry) > ~ Edited 2021-06-10 09:59 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 5770 |
I stand corrected! Oh yes, that's rather neat. :) I think it's one of those "Why? To see if it could be done, of course!" projects. lol Picomite info: I'm slowly adding bits to this as we go along. I'm not pretending that it's a manual, but more of a precis of what's been done. I've not added the UART stuff yet, so more updates shortly. Picomite doc a22.zip . . Edited 2021-06-10 16:39 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
a25 PicomiteV5.07.00a25.zip Fixes LOF, LOC and EOF This is the last update until later next week |
Thank you for all your hard work, Peter. You're a star! Now we have a few days respite from updating to concentrate on breaking it... A bit of a quick update to this as well, while I'm here... Picomite doc a25.zip . . Edited 2021-06-10 17:46 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 3589 |
I am a few versions behind (a23) but as promised, a test of the fft function. I expect this to be the correct result, at least I see the fundamental frequency and harmonics. The fact that the fft output is symetrical, when most applications only show half of the fft as a spectrum. I am not sure if the centre peaks in the fft graph are result of the start and stop of the sine wave in the input signal. Anyway, MATH FFT MAGNITUDE works. This is the code I used for testing. 'GFXterm - magnitude FFT 'init gfxterm parameters Const GFX=Chr$(16) Const ENQ=Chr$(5) Const ACK=Chr$(6) Print GFX "?" Input Gw, Gh Print GFX "clear" 0, 0, Gw, Gh GoSub drw 'defines n=1023 'samples for fft (multiple of 2 - 1) cy = 20 'cycles of sinewave in n samples Dim a!(n),fm!(n) GoSub sinfill GoSub sinshow Math fft magnitude a!(),fm!() GoSub fftshow End 'show fft on graphics terminal fftshow: Print GFX "ink" 255, 255, 0, 2 'scan magnitude array mi!=0:ma!=0 For i=0 To n mi!=Min(mi!,fm!(i)) ma!=Max(ma!,fm!(i)) Next i ' Print mi!, Ma! ygain=-Gh/(3*(ma!-mi!)) yoffset=Gh-1 xgain=Gw/(n+1) xoffset=0 For i=0 To n-1 x1=i*xgain+xoffset x2=(i+1)*xgain+xoffset y1=fm!(i)*ygain+yoffset y2=fm!(i+1)*ygain+yoffset Print GFX "line" x1,y1,x2,y2 Next i Return 'fill input array a() sinfill: For i=0 To n a!(i)=Sin(i*2*Pi*cy/n) ' Print a!(i), Next i Return 'show the graph of the input signal sinshow: Print GFX "ink" 255, 255, 0, 2 ygain=-Gh/5 yoffset=Gh/4 xgain=Gw/(n+1) xoffset=0 For i=0 To n-1 x1=i*xgain+xoffset x2=(i+1)*xgain+xoffset y1=a!(i)*ygain+yoffset y2=a!(i+1)*ygain+yoffset Print GFX "line" x1,y1,x2,y2 Next i Return 'draw frames drw: Print GFX "ink" 255, 255, 255, 2 Print GFX "line" 0,Gh,0,Gh/2+1 Print GFX "line" 0,Gh,Gw,Gh Print GFX "line" 0,Gh/2+1,Gw,Gh/2+1 Print GFX "line" Gw,Gh,Gw,Gh/2+1 Print GFX "line" 0,0,0,Gh/2-1 Print GFX "line" 0,0,Gw,0 Print GFX "line" 0,Gh/2-1,Gw,Gh/2-1 Print GFX "line" Gw,0,Gw,Gh/2-1 Return PicomiteVGA PETSCII ROBOTS |
Now I have no excuse to put off further weeding around and trimming the thorny flowering quince. Thanks, Peter--very much enjoying this journey. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 504 |
@volhout : wat is this graphical terminal and how to use it? Plasma |
I'm trying to verify Peter's demo for the UART setup but can't get it to work. I'm using different pins for UART0 (my SD card is using those), but in theory that shouldn't matter. Would someone like to check my setup please? 'UART test 'link 16-12 and 17-11 SetPin 16, uart0tx SetPin 17, uart0rx Open "com0:115200" As #1 SetPin 11, uart1tx SetPin 12, uart1rx Open "com1:115200" As #2 Print #1,"Hello World!" Print Input$(100,2) Print #2,"Bye World!" Print Input$(100,1) Close 1 Close 2 If I put an LED on the TX pins it flashes on transmit (I suppose!). Edited 2021-06-11 06:18 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
I'm away from my pico at present, but does loopback work on each? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Ah... I didn't try that. lol Not clear... With the prog as shown, linking 16-17 I get "Hel" :) Commenting out everything to do with UART1 that reduces to "He" UART1 doesn't seem to be working at all. Might be an overclocking thing. It's no hassle - I'll have more time to play late tomorrow afternoon. Just seems odd. Looks like something to do with timing. option cpuspeed 150000 baud rate at 115200 I get "Hell" but nothing from UART1 reduce baud rate to 1200 and I get nothing from either put it back to 115200 and got "Hello" the first time (then back to "Hell"). Oh - this is a25, by the way. Another edit: Got it working. option cpuspeed 250000 Had to add PAUSE 1 after each PRINT#n statement otherwise I got nothing. Also tried PAUSE 0.5 and PAUSE 0.8 but neither was ok. Edited 2021-06-11 07:12 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Print is non-blocking. If you do input immediately after the print then the data hasn't had a chance to be transmitted let alone arrive |
I figured I had to be something like that. If I slow down to 1200 baud the pause has to go a lot longer. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
use LOF to check for transmit complete |
Yes, I remember having that issue with serial ports when I was newer to the MM chips. I used(and still use) LOC to check for something in the buffer, and you can use a simple DO/LOOP to wait till there IS something in the buffer - if that is all you are waiting on. That idea would not work in code that needs to be doing other things too, cos it would halt the rest of the code while it waits only on the next message if you see what I am getting at. DO:LOOP UNTIL LOC(#1)<>0 'Wait for something to arrive in the buffer Pause 50 'Allow all of message to arrive in the buffer ... My problem was I did not have the pause command, so I was waiting for data in the buffer, then trying to process it before it had a chance to arrive - the interpreter was too fast! Adding the pause fixed that issue when I was learning. Or another way: DO:LOOP UNTIL LOC(#1)>=10 'Wait till there is at least one message in the buffer ... That will still 'Gotcha!' if there is LESS then ten bytes in the buffer and no new message arrives - it will sit there waiting again. That's why I pause, then read the buffer a byte at a time looking specifically for an 'End of message byte', which is unique and cannot be part of any message. The buffer then becomes an automatic message queue for you in the background. BTW, with the PicoMite - are the serial port buffers fixed, or can they be defined as in the other MMBASIC series of chips? Output buffer is fixed at 255 bytes in all the other chips I think, so just the input buffer is all I care about adjusting. If the input buffer is going to be fixed in the PicoMite, I can still live with that. Smoke makes things work. When the smoke gets out, it stops! |
DS3231 RTC module now working on picomite. This code sets the date and time. It is necessary to fill in the array hx() with the necessary values in hexadecimal Binary Coded Decimal (BCD) in the order shown in the comment on the first line. ' address,seconds,minutes,hours,dayofweek,day,month,year,control -- enter numbers in BCD as hex Dim integer hx(8)=(&h0,&h0,&h36,&h21,&h4,&h10,&h06,&h21,&h10) ' hx(0) is address to write to SetPin 14,i2c1sda SetPin 15,i2c1scl I2C1 open 100, 1000 I2C1 WRITE &h68,0,9,hx() I2C1 close End The following code gets the RTC values and sets date$ and time$: dim integer d(9) SetPin 14,i2c1sda: SetPin 15,i2c1scl: I2C1 open 100, 1000 i2c1 WRITE &b1101000,1,1,0 ' set the read address to 0 i2c1 read &h68,0,7,d() dt$=str$(bcd_bin(d(4)))+"-"+str$(bcd_bin(d(5)))+"-20"+str$(bcd_bin(d(6))) tm$=str$(bcd_bin(d(2)))+":"+str$(bcd_bin(d(1)))+":"+str$(bcd_bin(d(0))) date$=dt$:time$=tm$ ?date$,time$ end Function bcd_bin (Val as integer) as integer ' from FruitOfTheShed local integer tmp ' convert the BCD values to binary tmp = val AND &b00001111 bcd_bin = (val AND &b11110000) * 10 / 16 + tmp END Function Because RTCs have been built into many micro/maximites for a long time, I had to do some digging and experimenting to get it right. I found code from 2011 for the DS1307 using line numbers and different I2C commands, and a matherp offering with a CSUB. The bcd_bin function is derived from a DS1307 sub in FruitOfTheShed. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Edit: As this was off-topic, moved to a separate topic led Edited 2021-06-11 13:16 by led-bloon Miss you George |
Page 13 of 17 |
