Forum Index : Microcontroller and PC projects : PicoM + GFXterm: editor highlighting not correct
Page 1 of 3 | |||||
Hi Rob/folks, I noticed that Editor syntax highlighting from the PicoMite is not display properly in GFXterm (20-may-2020, RC) on the Raspberry Pi. Using "nes.bas": nes.zip PuTTY shows: GFXterm shows: Note the incorrect colours starting at Option Default and again at Pin(CLOCK_PIN%). Best wishes, Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
hi tom, it seems the pico port of mmbasic is sending some really weird/obscure escape sequences to set text colours. many terminal emulators (including GFXterm) simply ignore such text colour/attribute sequences, as there are far too many variants to support them all and throwing an error would be 'unreasonable'. here are a list of what i get from my pico (a25) with a typical page: ok? sequence occurrences effect/colour yes <ESC>[0m 2 normal text (reset to defaults) yes <ESC>[32m 3 green yes <ESC>[36m 23 cyan NO <ESC>[38;2;128;128;128m 2 bright black (grey) NO <ESC>[38;2;192;192;0m 2 yellow NO <ESC>[38;2;255;128;0m 4 orange NO <ESC>[38;2;255;128;128m 29 pink yes <ESC>[4m 2 dim foreground NO!!! <ESC>[97m 150 bright white (aixterm standard) the aixterm one (<ESC>[97m) is a doozy - i'm surprised anything supports that. fyi, here is the portion of code that handles SGR codes in GFXterm - i'd expect putty to be fairly similar in it's abilities: 'm':begin // set up character colours and attributes if S='' then S:='0'; n:=PC(S); // ShowMessage(IntToStr(n)+' |'+S+'|'); if n=-1 then fail else begin for I:=1 to n do begin J:= Pn(S,I); case J of 0:begin // ShowMessage('reset colours and attributes'); DimText:=false; InvText:=false; TxtStyle:=[]; FGcolour:=FGdefault; BGcolour:=BGdefault end; 1:TxtStyle:= TxtStyle+[fsBold]; // bold 2:DimText:=true; // dim FGcolour 4:TxtStyle:=TxtStyle+[fsUnderline]; // underline 5:begin end; // (not supported) 7:InvText:=true; // reverse video 30..37:FGcolour:=J-30; 39:FGcolour:=FGdefault; 40..47:BGcolour:=J-40; 49:BGcolour:=BGdefault end { of case } end; pass end end; cheers, rob :-) Edited 2021-06-13 02:34 by robert.rozee |
Hi Rob, Those "VT" codes do look odd, and unexpected too. I would have thought the Editor code would have been lifted from an earlier 'mite but I've had a very superficial grep through my archive of 'mite firmware source without seeing any such oddities; I only found code that generates the escape codes that GFXterm expects. Perhaps something else is at play. We may need Peter to explain this mystery. GFXterm is written in Pascal, Modula 2/3 or some derivative by the looks of that snippet? Best wishes, Tom Edited 2021-06-13 09:06 by thwill Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
it is indeed written in pascal, i've always found it much easier to work with than C. under windows i used "Delphi" version 5 (dating from 1999) for the original version of GFXterm, while for the linux version i use Lazarus (incorporating FPC). at some point i want to back-port the linux version to windows, so that a single set of source files can generate executables for linux, mac, win32, and RPi. lazarus supports this, i just need to get a win32 VM up and running. cheers, rob :-) Edited 2021-06-13 22:22 by robert.rozee |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8590 |
You Linux types should like the escape sequences. They are standard RGB codes. See the Wikipedia page on Ansi escape codes Edited 2021-06-13 22:48 by matherp |
You Linux types should like the escape sequences. They are standard RGB codes. See the Wikipedia page on Ansi escape codes. FC The RGB escape sequence is definitely supported by teraterm and putty Edited 2021-06-13 22:54 by matherp |
hi peter, it would seem that they are not supported on the putty Tom is running on his Raspberry Pi. perhaps Raspian has a special cut-down putty version? you have a palette of 16 standard colours (8 dim, 8 bright) available that is supported by just about every terminal emulator out there. the only things lacking are the colours pink and orange. why not just use that palette to maintain compatibility? btw, i used to be a windows 'type', exclusively, up until a couple of years ago. i clung on to windows until the very last moment, but in the end it just became too difficult. when i finally gave in and changed over to linux (as an absolute beginner) i was amazed at how much simpler life became - it was like returning to the early days of computing when the computer did what you told it to do, as opposed to the computer telling you what you were allowed to do. i am still only a linux beginner :-) cheers, rob :-) Edited 2021-06-13 23:53 by robert.rozee |
Tom says "Huh?" If you look at my original email it is GFXterm which isn't displaying the correct syntax highlighting ... unless they are both wrong and the output should be more colourful ... I did think it was a rather grey palette. +1 Peter can you confirm that the PicoMite EDITor is using different syntax highlighting colours to the earlier 'mites ? I (briefly) looked at the source for them and they all seemed to be using the standard 16 colour palette. I wouldn't call myself a "Linux type" either, I muddle along in both for work and it just so happens that the machine in my hobby area is a Raspberry Pi so that is what I use most often to access 'mites. As it happens I am more productive in Linux but I think that is because I have learned to favour command line tools and Linux comes with a better / more standardised collection of these - perhaps things will change if/as the Windows Subsystem for Linux takes off. Best wishes, Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
The PicoMite uses the same colours as other of my ports. It was a cut and paste. The standard MM2 colours don't work on a black background Edited 2021-06-14 02:13 by matherp |
JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 3659 |
Tom, What does echo $TERM show? (For non-Linux users, a brief note: TERM can be set to ask the terminal to emulate the device TERM is set to. It can be set to something unsupported, though...) John Edited 2021-06-14 02:46 by JohnS |
peter: that is correct wrt teraterm - teraterm maps 'light black' (gray) to completely black, hence you get black text on a black background. there have been numerous postings on here about how to fix this problem with teraterm: https://www.thebackshed.com/forum/ViewTopic.php?TID=10445#118834 as far as i am aware, most other terminal emulators (including GFXterm) work fine with the MM2. tom: with all that cyan and white, i'd assumed there was something wrong in putty too. can you get any other colours (ie, pink and orange) in the editor? cheers, rob :-) Edited 2021-06-14 02:48 by robert.rozee |
Tom, As you're using GFXterm I think TERM is likely irrelevant, sorry. John |
Thanks all, OK, no I haven't seen any other colours. The EDITors of the CMM1 and CMM2 both show the correct colours in PuTTY (though I believe the CMM2 EDITor source is completely independent of all the others) and I don't have any other 'mites to test on ... though BigMik is sending me one of his MX170 based-boards, coincidentally also called the Picomite I must be looking at the wrong piece of source-code, I was looking at the "VT100" constants in the Armmite H7's "Editor.c" file: //====================================================================================== // Attribute VT100 Code VT 100 Colour LCD Screen Colour //====================================================================================== #define VT100_C_NORMAL "\033[30m" // Black Foreground Colour #define VT100_C_COMMENT "\033[33m" // Yellow Yellow #define VT100_C_KEYWORD "\033[36m" // Cyan Cyan #define VT100_C_QUOTE "\033[32m" // Green Green #define VT100_C_NUMBER "\033[31m" // Red Red #define VT100_C_LINE "\033[37m" // White Grey #define VT100_C_STATUS "\033[30m" // Black Brown #define VT100_C_ERROR "\033[31m" // Red Red No worries, I believe the same applies to PuTTY which is also implementing its own terminal independent of the Linux one. Best wishes, Tom Edited 2021-06-14 19:19 by thwill Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
tom: yep, that colour table looks correct:"\033[30m" to "\033[37m", giving a choice of white, red, green, blue, cyan, magenta, yellow. combined with "\033[2m" to select dim foreground gives a total of 15 different colours. although i have a feeling that teraterm fails (a bug?) to implement the VT sequence "\033[2m", which then limits you to just the 8 bright foreground colours. with some tinkering with the teraterm configuration it may be possible to rectify this, although historically folks have struggled with working out how to reconfiguring teraterm and just opted for monochrome in the micromite editor! cheers, rob Edited 2021-06-14 21:12 by robert.rozee |
I've just had a quick tinker and that does appear to be the case as demonstrated by Print Chr$(27) + "[33m" Print "Hello" Print Chr$(27) + "[2m" Print "Hello" I guess we'll all have to abandon TeraTerm since it isn't as perfect as previously advertised You can of course go BOLD instead for 16 variations: Print Chr$(27) + "[33m" Print "Hello" Print Chr$(27) + "[1m" Print "Hello" Best wishes, Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
just realized i had a win10 netbook here that i haven't wiped yet, so did some experiments comparing teraterm to GFXterm. each has exactly the same code loaded onto an MX170 or pico. GFXterm, MX170: TeraTerm, MX170: TeraTerm, RP2040: note: TeraTerm has the palette change made so that grey text is visible. the file sizes (screen captures), despite being roughly the same dimensions, came out quite different, with the one from GFXterm about 4x larger than the TeraTerm ones. i eventually figured out what was going on - while GFXterm uses font dithering for the displayed text, TeraTerm seems to turn dithering off. this is, partly, why the TeraTerm text appears to be less smooth. cheers, rob :-) |
You missed out GFXterm + RP2040 ? Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 3546 |
pi pico MMBasic a25 GFXterm windows Putty Windows Teraterm (windows ...) Edited 2021-06-14 23:36 by Volhout PicomiteVGA PETSCII ROBOTS |
Thank you; that is what I observed previously and is similar (if worse) than what PuTTY on the Pi does. It seems the PicoMite, and presumably the Armmite, and maybe other recent 'mites (but not the CMM2 which has a different EDITor lineage) are "doing something different" to the earlier 'mites (as Peter has acknowledged). I only took a casual look at the Armmite source but it wasn't obvious why the standard VT100 colours were not being used ... the constants for them are still defined ... I wonder if the code-path/colours defined for rendering the console to an LCD panel are being used instead ? I guess it is in Peter's court now if he wants to "fix" this. Best wishes, Tom Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
There is nothing to fix. I'm using a perfectly valid escape sequence which as demonstrated above is correctly handled by both teraterm and putty |
Page 1 of 3 |
