Local Time 12:46 15 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Alpha Firmware - a27 onwards - starting on displays
     Page 6 of 14
Posted: 11:23am 24 Jun 2021
  matherp said  a26 . . . Couple of new commands
OPTION RTC AUTO ENABLE/DISABLE
OPTION MEMORY No_of_GUI_controls, program_memory_size
Each GUI control will take 52 bytes and the memory required will then be rounded up to a 256 byte boundary
Excellent additions. I appreciate the flexibility between program and variable memory. Re GUI, does this mean that 4 GUI controls take 256 bytes, and 5 take 512?
Is OPTION MEMORY a persistent option or one which a running program can set to suit its needs?
disco4now
Posted: 11:35am 24 Jun 2021
PIXEL commands is there. Any change of PIXEL function.
Latest F4 Latest H7 FotS
Posted: 11:47am 24 Jun 2021
PicoMite MMBasic Version 5.07.00a36
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> OPTION SYSTEM SPI GP2,GP3,GP4
> OPTION SDCARD GP5, 10
> OPTION LCDPANEL ILI9341, LANDSCAPE,GP20,GP19,GP18
OPTION TOUCH GP22,GP21
OPTION SYSTEM I2C 14,15
> ?date$,time$
24-06-2021      08:41:51
> memory
Program:
  0K ( 0%) Program (0 lines)
 80K (100%) Library
  0K ( 0%) Free
RAM:
  0K ( 0%) 0 Variables
  0K ( 0%) General
112K (100%) Free
>> OPTION MEMORY 64,60000
memory
Program:
 58K (100%) Library
  1K ( 0%) Free
RAM:
  1K ( 0%) General
129K (100%) Free
Sweet.
Posted: 12:01pm 24 Jun 2021
But ...
> option list
OPTION SYSTEM I2C GP10,GP11
OPTION RTC AUTO ENABLED
OPTION GUI CONTROLS 64
OPTION MEMORY 60160, 100352
> EDIT
Error : Not enough memory
> memory
Program:
 23K (31%) Program (919 lines)
 58K (100%) Library
4294967274K (-31%) Free
RAM:
  2K ( 1%) General
128K (99%) Free
23K program size, 128K Free RAM, but "Not enough memory".
This is with the program ccpico.bas in the zip file some posts back.
UPDATE: I tried again after power cycling: LOAD "ccpico.bas", then F4, and it works.
Edited 2021-06-24 22:05 by lizby
Posted: 05:34pm 24 Jun 2021
Using a36
I've not tested it with a program of any size in, but things seem to be working OK.
I've set OPTION GUI CONTROLS 39 to use just under 2k
OPTION MEMORY is showing 79104, 82688
But, like lizby found, there's a screwy calculation somewhere:
Program:
  1K ( 1%) Program (13 lines)
 77K (100%) Library
4294967295K (-1%) Free
RAM:
  1K ( 0%) General
112K (100%) Free
ILI9341 is sharing display & touch with SD card ok.
Clock is updating from DS3231 at boot ok.
OPTION AUTORUN 1 is loading & running the digital clock demo from the MicroMite manual.
docs update:
PicoMite docs a36.zip
Edited 2021-06-25 04:01 by Mixtel90
Posted: 06:09pm 24 Jun 2021
Hello Peter,
You've probably considered it already, but could you avoid partitioning the memory in advance (at least between variable memory and GUI controls) by allocating variables counting up from the bottom of the available RAM and GUI controls counting down from the top of the available RAM and then simply report an error if those two pointers ever cross ?
Edited 2021-06-25 04:11 by thwill
Posted: 06:20pm 24 Jun 2021
  Quote   You've probably considered it already,
Yes but no - it would be a major rewrite of a lot of Geoff's code
All there is an issue in b36 I need to sort and fix (the edit memory bug) so don't waste too much time on it
Edited 2021-06-25 04:29 by matherp
Posted: 06:37pm 24 Jun 2021
Have I understood this correctly?
There is a pool of 160k of RAM.
We decide how many controls we want:
ControlsRAM = <num_of_controls>*52 bytes rounded up to next 256 byte multiple.
FreeRAM is 160k - ControlsRAM
We can allocate up to 1/2 of FreeRAM as program space, the rest is used for both variables and editing. We could allocate, say, just 20k to the program to get some bigger arrays or something.
Posted: 06:41pm 24 Jun 2021
  Quote  Have I understood this correctly?
Perfectly - once its working
Edited 2021-06-25 04:42 by matherp
Posted: 06:44pm 24 Jun 2021
Well, yeah.  :)
Posted: 11:04pm 24 Jun 2021
FWIW, here's the pinout I used for the PCBs shown above. This configuration allows 2 SPI, 2 Com ports, 2 I2C ports, 3 ADCs, and a few free pins.
                          Pico 2x20   20x2 Pico
                             #  #  USB   #  #
               I2C0 SDA 1 |  0  3             | 40 VBUS
               I2C0 SCK 2 |  1  5             | 39 VSYS
                   GND  3 |                   | 38 GND
               SPI_SCK  4 |  2 19             | 37 3V3_EN
              SPI_MOSI  5 |  3 21             | 36 3V3(out)
              SPI_MISO  6 |  4 21 Pico        | 35 ADC_VREF
             SPI_CS_SD  7 |  5 37 I/O   12 28 | 34 Digital/ADC2
                   GND  8 |                   | 33 GND/ADCGND
                   p18  9 |  6 18       22 27 | 32 Digital/ADC1
                   p24 10 |  7 24       29 26 | 31 Digital/ADC0
               COM2:Tx 11 |  8 16             | 30 RUN
               COM2:Rx 12 |  9 11       36 22 | 29 T_IRQ
                   GND 13 |                   | 28 GND
              I2C1 SDA 14 | 10 27       33 21 | 27 T_CS
              I2C1 SCK 15 | 11 28       15 20 | 26 LCD_D/C
           (SPI2_MISO) 16 | 12 35       28 19 | 25 LCD_RST
                   p31 17 | 13 31       27 18 | 24 LCD_CS
                   GND 18 |                   | 23 GND
            (SPI2_SCK) 19 | 14 40       22 10 | 22 COM1:Rx
           (SPI2_MOSI) 20 | 15 38        7  8 | 21 COM1:Tx
                             #  #  USB   #  #
                          Pico 2x20   20x2 Pico
Within the vertical bars are the pico pin numbers (closest to "|") and the pin numbers on the 2x20 expansion port (numbering the same as on the CMM2).
panky
Posted: 11:47pm 24 Jun 2021
@lizby
Pico physical pins 21 and 22, GPIO 8 and 10??
Edited 2021-06-25 09:47 by panky
Posted: 12:12am 25 Jun 2021
  panky said  @lizby
You're right--Pico physical pins 21 and 22 should be GP16 and GP17. Thanks.
(No effect on the PCBs.)
led-bloon
Posted: 02:33am 25 Jun 2021
@lizby
I imported your Eaglecad files into KiCad and it would appear
that one track is incomplete. Pin 23 of the 40 pin header (SCK).
Then again, I am not a user of these softwares at all, so could
be just me!
led
Miss you George
Posted: 07:05am 25 Jun 2021
As things seem to stand at the moment:
Yes.
4 controls will fit take 52*4=208 bytes so will fit into the first 256 byte block.
5 controls require 52*5=260 bytes which will overspill into the next block, so will requite 512 bytes to be allocated. If you allocate 9 controls you get the next 4 for free! They will require 52*9=468 bytes.
OPTION MEMORY seems to be persistent. If you want to change it you will have to use OPTION MEMORY RESET then reallocate.
@matherp
Just wondering...
Rather than allocate GUI controls from a preset RAM allocation, could they be strings, arrays or even a Csub with the address(es) passed to the GUI handler? I suspect it might not be feasible without severe changes to the original code though.
Incidentally - had ARC running yesterday and it seems to work fine. :)
Edited 2021-06-25 17:18 by Mixtel90
Posted: 09:06am 25 Jun 2021
a37
PicomiteV5.07.00a37.zip
NB: file replaced at 10:40 UTC
I think I've removed the bug from OPTION MEMORY
Full GUI functionality now implemented
DISTANCE function now implemented (Take care HR-SR04 need 5V and PicoMite pins are not 5V safe - use a level converter)
NB: FLASH commands should work OK independent of MEMORY setting. Flash spacing is always 80K but save and load are based on the setting of the MEMORY option
' Demonstration program for the Micromite+
' It does not do anything useful except demo the various controls
' Modified for ILI9341 by Phil23
' Geoff Graham, October 2015
Option Explicit
Dim ledsY
Colour RGB(white), RGB(black)
' reference numbers for the controls are defined as constants
Const c_head = 1, c_pmp = 2, sw_pmp = 3, c_flow = 4, tb_flow = 5
Const led_run = 6, led_alarm = 7
Const frm_alarm = 20, nbr_hi = 21, nbr_lo = 22, pb_test =23
Const c_hi = 24, c_lo = 25
Const frm_pump = 30, r_econ = 31, r_norm = 32, r_hi = 33
Const frm_log = 40, cb_enabled = 41, c_fname = 42, tb_fname = 43
Const c_log = 44, cb_flow = 45, cb_pwr = 46, cb_warn = 47
Const cb_alarm = 48, c_bright = 49, sb_bright = 50
' now draw the "Pump Control" display
CLS
'setpin 18,dout
'pin(18)=1
GUI Interrupt TouchDown, TouchUp
' display the heading
Font 2 : GUI Caption c_head, "Pump Control", 10, 0
Font 2 : GUI Caption c_pmp, "Pump", 10, 25, , RGB(brown)
' now, define and display the controls
' first display the switch
Font 2
GUI Switch sw_pmp, "ON|OFF", 10, 45, 70, 30, RGB(white),RGB(brown)
CtrlVal(sw_pmp) = 1
' the flow rate display box
Font 2 : GUI Caption c_flow, "Flow Rate", 5, 75,, RGB(brown),0
Font 2 : GUI Displaybox tb_flow, 5, 100, 105, 25
CtrlVal(tb_flow) = "20.1"
' the radio buttons and their frame
Font 2 : GUI Frame frm_pump, "Power", 5, 140, 105, 90,RGB(200,20,255)
Font 1
GUI Radio r_econ, "Economy", 20, 160, 10, RGB(230, 230, 255)
GUI Radio r_norm, "Normal", 20, 185
GUI Radio r_hi, "High", 20, 210
CtrlVal(r_norm) = 1 ' start with the "normal" button selected
' the alarm frame with two number boxes and a push button switch
Font 2 : GUI Frame frm_alarm, "Alarm", 115, 115, 90, 115,RGB(green)
Font 1
GUI Caption c_hi, "Hi:", 120, 150, LT, RGB(yellow)
GUI Numberbox nbr_hi, 150,MM.VPos-6,40,MM.FontHeight+6,RGB(yellow),RGB(64,64,64)
GUI Caption c_lo, "Lo:", 120, 175, LT, RGB(yellow),0
GUI Numberbox nbr_lo, 150,MM.VPos-6,40,MM.FontHeight+6,RGB(yellow),RGB(64,64,64)
GUI Button pb_test, "TEST", 125, 200, 70, 25,RGB(yellow), RGB(red)
CtrlVal(nbr_lo) = 15.7 : CtrlVal(nbr_hi) = 35.5
' draw the two LEDs
Const ledsX = 125, coff = 50 ' define their position
ledsY = 50 : GUI LED led_run, "Running", ledsX, ledsY, 8, RGB(green)
ledsY = ledsY+25 : GUI LED led_alarm, "Alarm", ledsX, ledsY, 8, RGB(red)
CtrlVal(led_run) = 1 ' the switch defaults to on so set the LED on
' the logging frame with check boxes and a text box
Colour RGB(cyan), 0
GUI Frame frm_log, "Log File", 210, 10, 110, 160, RGB(green)
GUI Checkbox cb_enabled, "Log On", 215, 20, 20, RGB(cyan)
GUI Caption c_fname, "File Name", 215, 45
GUI Textbox tb_fname, 215, 60, 100, 20, RGB(cyan), RGB(64,64,64)
GUI Caption c_log, "Record:", 215, 85, , RGB(cyan), 0
GUI Checkbox cb_flow, "Flow", 220, 100, 20
GUI Checkbox cb_alarm, "Alarms", 220, 120, 20
GUI Checkbox cb_warn, "Warnings", 220, 140, 20
CtrlVal(cb_enabled) = 1
CtrlVal(tb_fname) = "LOGFILE.TXT"
' define and display the spinbox for controlling the backlight
GUI Caption c_bright, "Back Light", 230, 190,,RGB(200,200,255),0
GUI Spinbox sb_bright, 210, 210, 110, 25,,,10, 10, 100
CtrlVal(sb_bright) = 100
' All the controls have been defined and displayed. At this point
' the program could do some real work but because this is just a
' demo there is nothing to do. So it just sits in a loop.
Do : Loop
' the interrupt routine for touch down
' using a select case command it has a different process for each
' control
Sub TouchDown
Select Case Touch(REF) ' find out the control touched
Case cb_enabled ' the enable check box
If CtrlVal(cb_enabled) Then
GUI Restore c_fname, tb_fname, c_log, cb_flow, cb_alarm, cb_warn
Else
GUI Disable c_fname, tb_fname, c_log, cb_flow, cb_alarm, cb_warn
EndIf
Case sb_bright ' the brightness spin box
'BackLight CtrlVal(sb_bright)
Case sw_pmp ' the pump on/off switch
CtrlVal(led_run) = CtrlVal(sw_pmp)
CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 20.1)
CtrlVal(r_norm) = 1
Case pb_test ' the alarm test button
CtrlVal(led_alarm) = 1
'GUI beep 250
Case r_econ ' the economy radio button
CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 18.3)
Case r_norm ' the normal radio button
Case r_hi ' the high radio button
CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 23.7)
End Select
End Sub
' interrupt routine when the touch is removed
Sub TouchUp
Select Case Touch(LASTREF) ' use the last reference
Case pb_test ' was it the test button
CtrlVal(led_alarm) = 0 ' turn off the LED
End Select
End Sub
  Quote  OPTION COLOURCODE ON
OPTION DISPLAY 32, 132
OPTION CPUSPEED (KHz) 250000
OPTION SDCARD GP15, 10
OPTION SYSTEM I2C GP0,GP1
OPTION LCDPANEL ILI9341, LANDSCAPE,GP2,GP3,GP4
OPTION TOUCH GP5,GP6
GUI CALIBRATE 0, 180, 210, 880, 644
Edited 2021-06-25 20:39 by matherp
Solar Mike
Posted: 10:34am 25 Jun 2021
That looks very nice:
Are the PIO state machines available for use in the Picomite basic routines.?
Mike
Posted: 11:59am 25 Jun 2021
I don't think Peter has even considered what to do with the state machines yet, Mike. He's been concentrating on making MMBasic work to the proposed spec. :)
Posted: 12:52pm 25 Jun 2021
  led-bloon said  @lizby
be just me!
led
Not just you. Right you are. Just a tiny "air wire" missing.
Updated gerbers:
picomite_mcp2.3_2021-06-25.zip
picomite_1.3_2021-06-25.zip
And EagleCad files:
PicoMite EagleCad Ver 3.zip
Updated pinout:
                          Pico 2x20   20x2 Pico
                           GP#  #  USB   # GP#
                   GND  3 |                   | 38 GND
                   GND 13 |                   | 28 GND
                   GND 18 |                   | 23 GND
            (SPI2_SCK) 19 | 14 40       22 17 | 22 COM1:Rx
           (SPI2_MOSI) 20 | 15 38        7 16 | 21 COM1:Tx
                           GP#  #        # GP#
                          Pico 2x20   20x2 Pico
PicoMite on FruitOfTheShed
Edited 2021-06-25 23:24 by lizby
Posted: 01:55pm 25 Jun 2021
Regarding the ILI9488, is there any reason not to simply cut off the MISO pin on the LCD module?
     Page 6 of 14
© JAQ Software 2025
