Forum Index : Microcontroller and PC projects : PicoMite: driving a small speaker
matherp Guru ![]() Joined: 11/12/2012 Location: United KingdomPosts: 10233 |
My argument about this is only the inability to have a common ground for the speakers which means we can't use a 3.5mm jack socket. Otherwise there are lots of good solutions specifically LM4871 |
thwill![]() Guru ![]() Joined: 16/09/2019 Location: United KingdomPosts: 4301 |
Try: https://github.com/thwill1000/mmbasic-lazer-cycle/blob/main/src/spmusic.bas Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Mixtel90![]() Guru ![]() Joined: 05/10/2019 Location: United KingdomPosts: 7858 |
This is why I ordered some. I think it will be possible to drive phones, simply by ignoring the output from the second op-amp and capacitively copuling from the output of the first. The fact that you only get half power into headphones doesn't matter - you don't need it. :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Need it using PLAY. In your code the PWM frequency varies which means you can't have a filter that matches. I hit the issue trying the "entertainer" |
Qué? It is using PLAY SOUND providing you don't change the PLAY_MODE constant from the default 0 isn't it? Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Turbo46![]() Guru ![]() Joined: 24/12/2017 Location: AustraliaPosts: 1639 |
Try it without the filter too please. It might be prudent to add a 220R before the bases of the transistors on the left hand side just to protect the Pico's output. Bill Keep safe. Live long and prosper. |
Sorry, opened the link, first thing I saw was "setpin gpx, pwm" and gave up |
Tom doesn't need 20Hz...20kHz. Bill Keep safe. Live long and prosper. |
This is all understood but it would be great to find a generic solution that can be used by everyone rather than multiple application specific variants. |
It's OK Bill, this conversation has a life of it's own now. If I've learnt anything, it is don't talk about audio with old hi-fi enthusiasts ![]() Best wishes, Tom Edited 2023-03-26 04:21 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Sorry Tom, I though this post was supposed to be about your Tomboy project. ![]() Bill Keep safe. Live long and prosper. |
I've put a couple of 6L6s, some octal bases for them and an odd output transformer in the post for Tom. The 6L6s might be a bit heavy on batteries though. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
lizby Guru ![]() Joined: 17/05/2016 Location: United StatesPosts: 3358 |
I had hoped to learn something from this thread and the previous one, but I'm afraid it's back to the PAM8403 for me: ![]() Adequate and convenient is all I'm looking for. Kudos to those seeking something better. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Just use a potential divider before the input of the PAM module. You probably need to drop the signal to less than a volt. The volume control will take it up or down from there. If you do that you can run the PicoMite with PLAY VOLUME 100,100 to get best quality without overloading the PAM. The resistors will give you better control over the volume. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
mozzie Senior Member ![]() Joined: 15/06/2020 Location: AustraliaPosts: 132 |
G'day All, if there is a better way of opening a can of worms than starting a discussion on audio / hifi then I'm yet to find it ![]() Agreed Mick, the inductor really should be air cored and with low series resistance, its going to be bigger and more expensive than other complete solutions ![]() Peter's generic solution would be great but it's going to be hard to find because we all have different expectations / output requirements / power supplies available / space available and battery life concerns. Connecting earphones to my circuit would certainly do ear damage due to the residual 40khz carrier ![]() Thanks Tom, I downloaded the file and it plays on the Pico with the last circuit I published, I'll make a recording and try to upload. I see what you mean by the "ticks" between notes. Bill, the input side of the emitter followers are virtually open circuit, they have a current gain of 100+ and the output of the Pico swings 0-3.3v with very little loading so I'm not sure what the 220R resistors would be for, T5 in the bridge circuit requires a base resistor. Regards, Lyle. |
Just to protect the Pico if the transistor circuit fails. Belt and braces. Bill Keep safe. Live long and prosper. |
Unless you are jesting Google says you are sending me some valves ??? If that's the case then thanks, but ![]() ![]() ![]() Best wishes, Tom Edited 2023-03-26 05:34 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
stanleyella![]() Guru ![]() Joined: 25/06/2022 Location: United KingdomPosts: 2535 |
while waiting for the 4.7mH chokes, I looked for caps for the filter in the manual. 2.7nF will be 2.2nF in parallel with two 1nF in series, 68nF will be 47nF and 22nF in parallel, 33nF will be 22nF and 10nF in parallel. These are the nearest values I have. I can't find 2.7nF on ebay. Looking forward to trying sound first time. |
hitsware2![]() Guru ![]() Joined: 03/08/2019 Location: United StatesPosts: 719 |
I had hoped to learn something from this thread and the previous one, but I'm afraid it's back to the PAM8403 for me: ![]() Adequate and convenient is all I'm looking for. Kudos to those seeking something better. 99 % of the quality of the sound comes from the speakers , not the electronics . my site |
