Forum Index : Microcontroller and PC projects : PicoMite V5.07.01 betas
matherp Guru ![]() Joined: 11/12/2012 Location: United KingdomPosts: 6382 |
OPTION RESET clears the options to default. You then need to set up again the options you want including the sdcard |
lew247![]() Guru ![]() Joined: 23/12/2015 Location: United KingdomPosts: 1591 |
I did that I then went back to Version 5.07.00 dis the option reset and then OPTION SYSTEM SPI GP18, GP19, GP16 OPTION SDCARD GP15 OPTION LCDPANEL SSD1331, RL, gp21,gp20,gp17 The rest was deleted because again I'm an idiot I formatted the SD card in FAT on the computer and its now ok Don't use Exfat it doesn't work lol I can't figure out how to format it with the Pico though with a new card Edited 2021-11-10 01:35 by lew247 |
twofingers Guru ![]() Joined: 02/06/2014 Location: GermanyPosts: 1028 |
I think you can't. You should use a PC or something similar. Maybe this should be better/explicitly explained in the manual? Edited 2021-11-10 01:59 by twofingers |
homa![]() Newbie ![]() Joined: 05/11/2021 Location: GermanyPosts: 18 |
you see that right Please provide demo code and instructions as to what to do to create the issue Backlight 75 GUI NUMBERBOX #1, 100,200,150,35,RGB(YELLOW),RGB(BLACK) CtrlVal(#1)="##123" GUI textbox #2, 100,100,150,55,RGB(BLUE),RGB(BLACK) CtrlVal(#2)="##Hier Text" That's all, i was just trying to understand and test the commands. I provoked the behaviour by pressing the virtual key for a long time. No, there is no way to limit the length of the entered text. However, you can trap the key up interrupt and rewrite the text (ie, truncate it) to suit your application. That's a pity, because it would have made things so nice and simple with just the command. Another option "max length" would be a great thing. Or even better the check with regex :-) Sorry for the delayed answers, but I am 10 hours behind here in Germany. |
Is this the answer or solution to the problem? https://www.thebackshed.com/forum/ViewTopic.php?TID=14239&P=3#177476 That's right: A collective thread would be great. The version and a keyword would then be in the header. The rest is in the text. |
Mixtel90![]() Guru ![]() Joined: 05/10/2019 Location: United KingdomPosts: 2779 |
I'm not sure that string length detection in a text entry box could be made to work without a lot of messing about. The number of characters changes with the size of the box, the font size and how many blank pixels you want at each end of the string. All these are fixable if you use the key up interrupt. You could even enter right or centre justified text that way. Likewise with numbers. You could even shrink the font after x number of characters to allow more characters in the box for, say, a long part number. Adding ease of use often takes away flexibility. It's a balancing act. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Kabron![]() Regular Member ![]() Joined: 30/11/2017 Location: GermanyPosts: 62 |
Does anybody knows the reason? OPTION SYSTEM SPI GP18,GP19,GP16 OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13 OPTION TOUCH GP12,GP11 GUI CALIBRATE 0, 124, 231, 875, 646 ? MM.VER 5.070106 print MM.INFO$(SDCARD) Ready > files A:/ 1408 bench.bas 3248 fft.bas 640 grain.bas 1536 menu.bas 896 sieve.bas 512 speed.bas 4608 ta.bas 4736 tain.txt 0 directories, 8 files > load "bench.bas" > > save "test.bas" Error : A hard error occurred in the low level disk I/O layer > Warning: SDcard Removed > files Error : SD Card not found Edited 2021-11-11 20:02 by Kabron |
Only a guess... You have a problem with that SD card. Not all of them work and I've seen similar things happen. Part of the problem is that it takes less current to read than it does to write. Writing can take a lot of current on some cards, causing volt drop and causing the card to shut down. Once that happens it's flagged as being removed. Sometimes you can add a filter, a low value resistor and an electrolytic capacitor in the VCC line to the card. That doesn't always fix it (been there, done that). The answer is generally a new card from a reputable manufacturer. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
jirsoft![]() Guru ![]() Joined: 18/09/2020 Location: Czech RepublicPosts: 526 |
5.070106 Error : A hard error occurred in the low level disk I/O layer > Warning: SDcard Removed > files Error : SD Card not found I have similar problem more often on CMM2 after FW update from 5.07 to 5.0701, never had it before... Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), CMM2.fun |
Solved by shorting 1k resistor in SD_SCK line on ILI9341 shield. PS All resistors were changed to 91 Ohm + 10uF capacitor to power lines. Edited 2021-11-11 23:29 by Kabron |
Good news! I'll try that with the cards that wouldn't work previously. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
no idea i had the same error sometimes, sd card in out helped ... but i think it is and remains a bug |
wolfme Newbie ![]() Joined: 26/10/2021 Location: GermanyPosts: 26 |
I had exactly the same problem and this is the solution. Thanks for sharing. Wolfgang |
dMajo![]() Newbie ![]() Joined: 18/05/2020 Location: ItalyPosts: 21 |
Hi Peter, the download links are broken |
panky![]() Guru ![]() Joined: 02/10/2012 Location: AustraliaPosts: 975 |
b6 here downloaded fine for me. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
phil99![]() Guru ![]() Joined: 11/02/2018 Location: AustraliaPosts: 594 |
http://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Gets this result "403 Forbidden Access to this resource on the server is denied!" But this works fine. https://geoffg.net/picomite.html |
Poppy![]() Guru ![]() Joined: 25/07/2019 Location: GermanyPosts: 486 |
Gets this result "403 Forbidden Access to this resource on the server is denied!" But this works fine. https://geoffg.net/picomite.html I have the same issue clearly depending on the browser I use. Old WATERFOX shows the same denied access but new FIREFOX works fine and the usual download window opens! ![]() ![]() | ||||
I always have a problem downloading from Geoff's site using Pale Moon - it doesn't work. Vivaldi works fine, no problem. There are other sites around (my bank is one) that Pale Moon is having problems with now, Geoff's isn't the only one. I suspect that they are only testing with Chrome-based browsers and, possibly, the current Firefox now. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Works fine in edge, chrome and firefox (W11) |
Edge, Chromium, Opera, Opera Neon, Vivaldi, Epic, Brave, Comodo Dragon, SRWare Iron and probably a few more are all based on the Chrome browser. Most probably don't send quite as much of your data to Google than Chrome does. Firefox is probably the last of the major browsers that isn't based on Chrome. Chromium is the open source version of Chrome. It's also owned by Google, who use it to try things out on. In theory it doesn't send your info to Google, but who knows? It's a lot of code to examine if you want to be certain. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
